Justin Reade
What exact setting(s)/codec in COMPRESSOR would you use to achieve the highest possible resolution on a SD DVD, when you're working with a 1080/24pA source from Final Cut Pro 5.1?
For example, would there be an ostensible difference between the resolution of my SD DVD, if I simply EXPORT from FCP 5.1 using "Quicktime Movie" and burn that to disc using DVD Studio Pro, versus if I use Compressor for my FCP export?
If the answer is YES -- that you can achieve a better looking SD DVD by using Compressor upon export from FCP 5.1 -- what precise settings should one use in Compressor?
Thank you.
Justin.
Thank you.
Justin.
