Best card to use with ML and Qscale
i guess most people will recommend you the sandisk extreme 30mb/s
i was looking into a cheap alternative since i find 108$ for a 16gb sd card a bit overpriced... but a lot of sd's on the market that are labeled class 10 will not keep their promise (had horrible experience with adata)
i bought silicon power 16gb and they work quite well. sometimes i get the buffer symbol in 720p50 but the recording never got interrupted so far. check this chart at toms hardware for a speed reference on sd cards. i also found out that my transcend 8gb sdhc class 6 are even faster then the silicon power... so i guess if you want to be sure to get a fast cheap card i would look for 8gb
but for for full performace bigger sd's you'll want the sandisk 30mb/s.
I have the 8gb Trascend class 10 and it topped out at -8 qscale
is there any card wich can reccord at -16 qscale?
umm, i would presume the fastest rated cards? i just bought a 16gb sandisk 90mb/sec (600x) speed card and i plan on testing out the qscale settings with it
