J jmarkham Well-known member Mar 4, 2009 #1 Is the mount on the HPX300 an AB gold mount or v-mount? thanks, jeff
Kenn Christenson Well-known member Mar 4, 2009 #2 AB Gold Mount. If you're currently using V-Mount Batts, you can get an adapter.
J jmarkham Well-known member Mar 4, 2009 #3 yup .. i'm all V-mount .. is the IDX one any good? thanks jeff
David Saraceno Moderator Staff member Mar 4, 2009 #4 I believe you need both an adapter bracket and a v mount that ADAPTS 3-STUD MNT TO V-MOUNT
Kenn Christenson Well-known member Mar 4, 2009 #5 We use the IDX adapter - http://www.bhphotovideo.com/c/product/230276-REG/IDX_A_AB2E_A_AB2E_V_Mount_Adapter_Plate.html and it's all we needed for our HPX500.
cheezweezl Veteran Mar 4, 2009 #6 ya that adapter is solid. i have one on my 500. plus it leaves the door open for both battery options. much better choice than changing the plate imho.
J jmarkham Well-known member Mar 4, 2009 #7 Thanks for the replies guys ... I've got my IDX adaptor on-order at Beards and Hats ... jeff
