I had a hint of a problem a few days ago. The Live View screen on my GH5 was not as bright as it should have been, but when I pushed the shutter button down half way it returned to normal, however if I released the shutter button it would go darker again. Not totally Black but about 4 stops darker.
All of a sudden this problem seemed to go away and I thought it was something I had done so I promptly took it off my mind.
This morning what might be connected or another problem showed up when Up-Grading my GH5 Firmware to Version 2.0, as follows.
I went through the up grading process carefully and Version 2.0 is now installed, however after I confirmed that Version 2.0 was in fact on the camera and then went back to live view the camera automatically powered down…………..I tried turning it on and off several times with the same result. When I get out of the menu to use the camera in live view, it automatically powers down every time. Oddly enough, as long as I’m using the menu it stays on.
Is anyone else having this problem and if so is there a solution???
