Someone else may have already posted something like this but I (think i have) thought of a great way of backing up the 16 gb p2Cards to DVD. I used to use 4gb cards and that was no problem to back up, but now i have several 16 gb cards, which doesn't fit onto a DVD-R. What i thought of doing, and have starting doing, was create 4 Burn folders for one 16 gb card.
My method:
1. place the LASTCLIP.TXT file on every disc.
2. Create a CONTENTS folder on every disc.
3. Copy the folders CLIP, ICON, PROXY, VOICE onto every disc
4. Create an AUDIO and VIDEO folder
5. Copy over as many video clips (that will fit) to the new VIDEO folder
6. Copy over the correlating audio clips to the new AUDIO folder
7. Do this for all 4 discs.
This seems like the best (affordable) way to back up the footage to a disc without having to get a blu-ray burner. 16 gb p2 cards partition the cards into 4 drives, so if you record straight 40 minutes, you will end up with 4 different perfect sized video files for each DVD. The downside? It seems like there is huge opportunity for Human Error. Especially if you shoot many shots and have to really stay organized to get a perfect 4gb of footage. you might need to skip a clip because of file size and not stay in perfect 1,2,3,4 order but have to copy 1,2,4 then have to burn 3 to a different disc.
I have been able to transfer clips off the disc (it gives you a message "preview unsupported for this clip" for the clips that are on different discs). There may be clips that are spanned. in this case, you have to copy the disc to a hard drive and re-compile the card as if it was a 16 gb card.
I was wondering if anyone else has tried this or has any thoughts to this method?
My method:
