andybiz_2005
I have a DVX102AE (PAL) version of the camera & I read somewhere about adjusting the back focus with a focus chart & the instructions goes like this :
Before starting, mount your camera on a tripod and adjust your camera's viewfinder to achieve sharp focus.
Ideally, you should place our free test pattern chart at least 25 Metres from the camera (If you can't place the chart 25 metres away just position it as far away as possible).
Set the iris to manual
Set the zoom to manual
Open the iris to its widest aperture - If the illumination on the test chart is too bright for the open iris, reduce the light or move the chart to a darker area
Zoom fully into the centre of the chart (maximum focal length of the lens)
Focus on the chart
Zoom out fully
Loosen the back focus ring retaining screw
Adjust the back focus ring for the sharpest focus
Repeat steps 4 through 8 until focus is sharp throughout the zoom range
Tighten the back focus ring retaining screw to secure the ring
Note: Most lenses are at their sharpest focus between f4 and f8
I'm curious to know if my DVX102AE has a back focus ring & if I need to use a focus chart to adjust the focus on my DVX? Is it neccesary, or not neccesary to adjust the back focus as the DVX already has auto focus settings? Thank you all for your advice.
Andrew
Focus on the chart
Zoom out fully
Andrew
