I believe it won't have HD-SDI at all, just HDMI.
These are exciting times indeed! Panasonic must have shaken Sony quite a bit. I am very curious what the others will do: JVC? Canon? QUOTE]
I think all of these models stem from the introduction of the RED camera, the threat of Scarlet, and the huge unexpected popularity of the VDSLR. The AF-100, F3, NXcam & AF-200?? releases were probably pre-planned in the secret industry control meetings in Japan. Panasonic goes low first, Sony goes higher with each company offering the opposite down the road...
Just my view from the outside.
Utter nonsense. You are aware, are you not, that the VariCam, the F900, the solid-state revolution, the HVX200 with its variable frame rates, the budget shoulder-mount HD100 with its interchangeable lenses and cinema lens adapter, the whole HDV format, 4:2:2 in a great codec in a cheap camera, HD-SDI, and all those things came about before Red was even first teased, don't you? And that the entire DSLR revolution came and went after Red announced the Scarlet, and there's still no Scarlet...but can you imagine the world of video without RED, a world in which only Sony, Panasonic, Canon, and the other big ones are the only actors? We will still be in the era of DV if it were for them.
but HDMI is still an uncompressed 10-bit HD signal
Not the same. HDMI doesn't have timecode. No timecode means no useful multicam, no timecode slates, no sync'ing with external audio recorders, no timecode to your external video recorder... not to mention that the HDMI connector is simply unacceptable for real pro use. It's okay for a cineroid, I guess, but the HDMI connector is as bad or worse than the 4-pin firewire connector. Just awful. I don't think I've ever even used the HDMI connector on my AF100s... bah.Assuming that is only has HDMI output, a SDI converter costs about $500 list. Or you could feed this to the NanoFlash / Ki Pro Mini which can also convert the signal to HD-SDI.
