Baby F3 aka NXCAM S35
Ill stand up and say some cheap adapters are really good and have no play at all, but you may have to buy a few to find a good one.
For example my first nikon->m43 adapter had play on both sides of the mount, my new nikon "G" adapter has no play at all- both were about $30 on ebay. (surprisingly the "good" one is from rainbow imaging)
Do not buy cheap lens adapters. They do not achieve a tight fit. I had a Fotodiox to use Nikon lenses on my GH2 and it was so loose and wiggly that moving the follow focus would WILDLY reframe my shot. Never got a chance to see if the Novoflex was actually worth the extra money because I wised up and traded the GH2 in for a D7000 (still not what I'd call a sturdy camera, but it's a Hasselblad compared to the ridiculous GH2).
Sorry you had a bad experience, Lee, but I agree with Hunter. There are good $30 adapters and bad $30 adapters. My inexpensive Chinese Nikon G to micro 4/3 adapter creates a very solid fit between my Nikon glass and my GH2. There is zero "play" between the lens, adapter and camera when I focus, zoom, or change apertures. So I'm a little confused by your solution to the problem. How does a poorly made adapter make the camera "ridiculous"? Or was there another problem with the camera, in your view?
I kinda figured these random eBay lens adapters would be WORSE than the one I bought which was at least from a brand anybody had ever heard of. Guess I just have bad luck haha.
Oh no, that was a separate thought. I just decided the GH2 was wayyyyyy too light and flimsy for my taste. The D7000 isn't a huge amount better, but I can work with it. But I shot with a D2x for years and find even my D700 a little under-built sometimes (CF card door especially) so no one should go by my opinion.
Anyway sorry for going off-topic.
I've been wondering about the E-mount on the NXCAM S35...
I currently own the VG10. Both of the cameras will share the same lens mount, so the Sony 18-200 lens on my camera will work on the NXCAM.
But, how does this work? The VG10 has a smaller APS-sized sensor. How much different will it be from a Super 35 frame?
Marginally, if at all. APS-C is 22mm wide. Super35 is 24.9mm wide. The F3's sensor is 23.6mm wide. In other words, it's a minimal differernce.
I thought the F3's sensor was considered to be Super 35? Just a tad smaller, I guess.
They call it Super35, but it's smaller than the actual film Super35 size. As is the Red One and most of these cameras. I think on Abel's chart the Red Epic is about the only one that actually is or exceeds the size of S35.
It's off topic but since we started: Film is always masked when projected in the cinema. So we usually don't see the full frame. By the way, super 35 is not a distribution format, but that doesn't matter in this respect. The cropping as well explains, why sometimes a boom is very obviously in shot. This is often caused by a wrong masking of the frame in the cinema.
The E mount has a shallow flange distance similar to micro 4/3's so it is certainlly possible. Someone will probobaly make one eventually.
I have seen several PL to E mount adapters on eBay for the little NEX cameras. This one from Taiwan is $156 (shipping included).
reading between the lines....no pun intended ....the gh series are by far the best deal and I find it hard to believe that high bitrate mpeg from a hacked gh1 didn´t perform better( he relates his experience of his gh1 to the af100 performance) ...from the samples I´ve seen - as I said ...reading between the lines - can hardly wait for the fs100 is added to the mix
What is good is that the base F3 without slog is already at 12 stop of dynamic range, which bodes well for the NXCAM because we won't have s-log. I think the test was made with the standard codec, so perhaps we could get even better dynamic range from a clean HDSDI or HDMI output.
He is saying that with certain gama he is seeing an hint of another stop, perhaps with a cleaner signal we could get 13 stops. That would be extraordinary if tomorrow we could se a 12 - 13 stop dynamic range camera in the $ 6000 range. If the NXCAM/FS100 shares the same image characteristic with its bigger brother it will be a real revolution and will overshadow the AF-100.
http://provideocoalition.com/index.php/awilt/story/ag-af100_and_pmw-f3_on_the_charts/
If you read the article above you will see that it is not me who is saying that. Provideocoalition has for me the best set of test on the different high end cameras on the internet. You will see test of the Alexa, Red MX, 5d, etc on there site and the methodology which is for now considered to be the most accurate system (back-lite graduated chart). I saw this more subjective test
One thing it shows is that F3 sensor is more the type that you can extract a lot from the shadows to get the most of the dynamic range.
