[FS: General] Awesome Oct-19 LOMO PRIME SET!! (& Micro4/3 Adapter)
qwerty123
Up for sale is a fine set of OCT-19 mount Lomo lenses.
I’ve tried to hold onto these lenses for as long as I could, but unfortunately financial circumstances mean that I must let them go. My loss—and labor in collecting this set—is your gain. The set is color matched (with a caveat I explain below).
I’m asking $3200 (EDIT: $2,600) for the full color matched, 7 LENS SET. This price includes the nearly new pelican case + shipping within the continental USA.
I’m open to selling these lenses in seperate bundles as indicated below.
I also have an Oct-19 to Micro 4/3rds adapter that I got from cieco7 on ebay, and I’m willing to sell that at a significant discount for anyone interested.
Below is a breakdown of the 7 lenses, following which are details and pictures:
Here’s the breakdown of the lenses, following which are details and pictures:
18mm OKC1-18-1 (#780067) t3.4 & 18mm OKC1-18-1 (#780199) t3.4 -- $580
22mm OKC3-22-1 t2.3 -- $450
28mm OKC4-28-1 t2.4 & 35mm OKC11-35-1 t2.2 -- $780
50mm OKC t2.3 & 75mm t2.2 -- $950
Here’s a picture of the set in the Pelican case:
None of these have any fungus or haze on them, and if there is any race of dust in them, it’s very very minor. Onto the specifics.
I’m only allowed to post 5 photos here—so detailed pics of the 35mm and the 75mm couldn’t be posted. But if you contact me, I can send you photos of these, and more photos of the others!
18mm #780067
Smooth focus, iris is smooth but a just little stiff. This lens is significantly lighter in weight than the #780199. This is the only lens in the set that seems to render color just slightly different from the others. There’s a little yellow bias I found.
18mm #780199
Focus is smooth but a bit hard. Iris is smooth (almost too smooth). This lens is heavier than the other 18mm, and has a brass focus ring. It’s color matched to the rest of the lenses. There’s a slight smudge on the back rear optical element that I think is perhaps oil, but I’m unsure. I tried to indicate this on the picture. In any case, it’s optical performance is the same as the other 18mm.
22mm
Focus and iris are smooth. It has a 32 pitch gear installed on it.
This lens doesn’t have a serial number listed. But I’ve tested this lens against a 22mm from 1992 (that I sold here), and the 22mm I’m now selling was a sharper, better performer throughout its range.
28mm
Focus smooth; there’s some discoloration on some of the iris blades (which can be hard to see at some angles) but it turns like butter.
Note that this is not the OKC7-28-1. And the reason I didn’t go for that lens and went for this model instead was based on an email exchange I had with Olex Kalynychenko. He informed me that the later model tends to be more prone to problems because of the design of its optical block (something about the third element being glued in a particular way). The OKC4-28-1 doesn’t have this design feature. Plus this particular OKC4-28-1 I found was in great condition.
35mm
Focus and iris smooth. Sharp, great lens. Like the 50mm, I test this 35mm against a 90s counterpart which I sold here. I kept this one because it was sharper performer.
50mm
Great lens! Focus is smooth. The iris ring on this lens is smooth, but gives a bit more resistance between t4 and infinity than from wide open to t4.
Like the 35mm, I test this against its 90s counterpart. And I kept this one because it’s sharper.
75mm
Focus is smooth and great. The iris is smooth but a bit stiff (works properly of course!). Otherwise, the lens is in an excellent condition, and is just beautiful throughout its range.
Price drop to $2,800 -- (including shipping in the continental USA) -- last call before ebay!
I have test pics taken with the lenses. If interested, PM me.
@j-cal yes they should -- they were originally designed for 35mm film. The main thing is that some lenses -- like the 18mm and maybe one or two others -- don't work well with some DSLRS that have mirrors in them: not enough room. But with any mirrorless camera system you are fine!
Price drop on whole set to --> $2,600
People have used these lenses with the RED (including in the film "The Loneliest Planet") So it could be a great option to take some of the "digital edge" off of the GH4 in 4K!
Individual lenses also price dropped:
If you are selling these items individually, we only permit five or less items per thread under our Guidelines.
You have seven items.
