wgzn Veteran Sep 18, 2010 #1 i have a show shot on dvcprohd (hpx170) b-camera shot avchd (hmc40,70,or something) is there any benefit to transcoding the avchd to ____ before bringing it into FCP to mix with the dvcprohd from the 170?
Jason Adams Section Moderator Sep 18, 2010 #2 Panny does have an AVCHD to DVCPRO transcode utility. It would let you log and transfer everything with the same workflow. https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/avc_download.htm
David Saraceno Moderator Staff member Sep 18, 2010 #4 Use ClipWrap2 and go directly to DVCProHD. Best $49.00 you'll spend.
wgzn Veteran Sep 18, 2010 #5 will give that a look david. thnx! update: tested clipwrap2. it did the trick! Last edited: Sep 18, 2010
