I hooked up an AV cable (with the 3.5mm 3 rings male to three RCAs yellow composite video and red and white audio) but couldn't get a video signal on the composite input of a monitor. The HDMI is working fine. I'm being asked to feed my signal (that I'm recording) to an overflow room and am not too sure what is the best way to go about doing that with a C100.
Is it not a typical AV cable for the C100? I have no idea how far my run will need to be. Should I convert HDMI to SDI (expensive) or maybe simply DVI (a cheap converter)? The feed will go to a projector and audio is not my problem.
