Since upgrading my c100 2-3 weeks ago, I have noticed that the one touch auto focus is not working properly anymore. I mentioned this in another thread and someone else is having the same problems. Here is what is happening:
point your camera at an object that has good contrast.
press the auto focus button and hold it.
the focus starts to move around to find the focus point but then stops well before it is even close and is done.
try again, and it does the same thing. Repeat multiple times. It only seems to work about 1 out of 5 times.....roughly.
Prior to this upgrade this feature found focus every time. With the rare exception if I was pointing it at a wall that was flat lit....it might not find enough contrast....which is to be expected.
I know auto focus is not a big deal to many on these forums (and even to me most of the time) but I do use it sometimes to setup shots and it can save your backside in certain scenarios.....so to have it actually become worse after this firmware upgrade is indeed a disappointment. It was also a bonus reason I switched from the Black Magic Cinema camera also...
Can we get a group of us to test this out? If this is indeed a problem across the board we need to let Canon know about it.
Thanks.....I hope some of you can add to this to see what is going on here.
