Eric Coughlin
Would you recommend manual or automatic gain for audio when doing run n' gun work?
This question is both if you are using the top handle with a shotgun attached, making manual audio adjustments easier, as well as using just a mic (such as the Rode Video Mic Pro) plugged into the mini-jack for a smaller setup. Obviously without the top handle you have to go into the menu system to change the levels which makes it more difficult on a fast paced shoot. I found with DSLRs I got considerably better results (such as during wedding preparations) with setting the audio manually, but since the C100 has significantly better pre-amps, and perhaps better auto gain control, that it may not be necessary to manually set the levels in a fast paced environment.
Also regarding the top handle, is the audio any better through the top handle (using XLRs) vs through the mini-jack, or is the quality the same? I have an Audio Technica 875r (Phantom Powered) and a Rode Videomic Pro, so I was wondering what would be more likely to get better quality. Having the top handle also allows for higher end shotguns which typically are XLR and require Phantom Power. I'm considering a Sanken CS-3E down the road and was wondering if using that in the top handle would be much better sound for run n' gun than a Rode Video Mic Pro into the mini-jack.
With DSLRs I would typically set the Rode Video Mic Pro to +20db so the pre-amps would not have to be used as much in the camera; is this not recommended for the C100 since the pre-amps are much better than DSLRs, or would the +20db still help so as not to use extra boost from the (already good) C100 pre-amps?
