ChrisHarding
Hi Guys
My AC-130 manual seems to be very vague about specs regarding the audio limiters on Channel 1 and 2 !! It shows a little diagram with a vertical line at -12db and another line at 0db. Does anyone know when the limiter actually kicks in when you are manual audio?? and at what level...the diagram seems to indicate that any signal higher than -12db is attenuated down to -12 ... I admit I do like my audio level at weddings to be around the -6db level. Does the limiter "set itself" on a high level and then keep everything below that level.
Who knows exactly how the limiters work and do they do an "auto adjustment" or just clip the waveform...If you run a test in auto the waveform with loud DJ music most definately looks like it has been given a "haircut" the camera seems to chop the top peaks of the signal but doesn't do anything to the bottom part of the waveform.
I would love to have some clarification on the limiters from someone who knows?? What do most shoot on..I have been, for now, just running manual on both XLR's with limiters off as I would rather have some peaks to contend with during wedding vows than have everything dropped too low!!! I sometimes will have a bit of wind noise (often from the officiant's mic) and if the limiter "sees" that as an excess level I don't want it to then drop my mic level down based on that one wind spike!!!
Some clarification would be very nice and I can see why Barry has a book out for the 130/160...the manual is really poor nowdays!! (My little Lumix FZ50 still camera has a way better written manual!!)
Chris
Chris
