Aspect Guide display on Component out
mvansomeren
I finally got an external HD monitor that uses component inputs.
I have my A1 set up to display the 2.35:1 aspect guide lines on the LCD view Finder.
When I had an external monitor that used Composite inputs connected, (wth TV OUT turned on in the A1's menu) I could see all of the display information, zoom, battery, frame rate, etc. AND the 2.35:1 aspect guide lines.
Now that I am using the HD monitor that uses component inputs, I see all of the same display data EXCEPT the aspect guide lines. I have scoured the manual to see if there is any indication that this isn't available on component out or if there was something in the custom display functions that I needed to turn on but I couldn't find anything.
Any of you A1 / external monitor users out there figured out how to do this, or is this something that just doesn't work on the Component out of the A1?
Thanks!
