Tony Hernandez
Prores at 4K and UHD with a new 3.4K sensor
http://thehouseofvideo.com/arri-unveils-new-alexa-sxt-camera-with-4k/
I can't handle the Red forums at all, such zealots.
It's the same sensor and, in all likelihood, a lot of processing power and a new top notch algorithm, far beyond to what one might get in a current 4K TV set, that help ARRI make this assertion. Hypothetically speaking, one can get above the native resolution of a sensor with pixel shifting as Olympus is doing with its EM5 MK II - although, this is not what ARRI is claiming with this camera - and, at some point, one should see this in video products. From the current releases, EM5 MK II can deliver a 40 MPX image out of a 16 MPX sensor. The only catch is that you can't shoot moving images due to the time it takes to process the pixel shifting itself. If your object is not stationary, then it comes out blurred. The Olympus managers stated that they should be able to do it with the next generation of that model.
But - EM5 MK II is a $1,100 camera retail. SXT is ... well, far, far, far higher priced and so I wouldn't be surprised, if in lieu of increasing the pixel count of this very sensor, ARRI simply decided to pixel-shift its way to 4K and then beyond it.
but I doubt the current generation of Alexas will ever have a true 4k 16X9 sensor
To read this kind of posts against RU where the forums were born by the same founder and President of associated cinema camera project is beyond any good sense of accurate perspective on balanced facts as much as same family members or close relatives (or not so close) hating each other... for no sense or pure trivia with no exact clue whyThis is a ridiculous comment. The RED furum, like this forum, is full of very talented and insightful people...many of which are absolutely professionals who are open to all great forms of imaging tech.
Right but, hypothetically, it can be uprezzed to an imperceptible level (and beyond 4K). An off-the-shelf 4K TV will upres a 1080P image to 4K to only a subtly inferior quality compared to a native 4K footage using a processor in a (educated guess) $30-$50 range. Alexa SXT, given its price tag, can afford to increase an in-body processing power far beyond that. At that point, the question becomes not what ARRI has managed to create rather than recreate. In other words, it will look like a 4K image but the question is whether it will look the same as a 4K image taken by a true 4K sensor. The analogy will be closer to a digitally remastered audio from the olden eras. It's impossible to create a modern quality recording from the 1930's original (presuming a vinyl record and not film/optical) but, the closer you get to the dawn of digital of the late-1970's-early-1980's, the finer the remastering can be. SXT is basically doubling its pixel count and I assume the end result won't be worse off than an authentic 4K product.Arri actually just uprezzes the footage ...
The current and continuous pixel race is toward 8K. 4K is merely a pit stop.... I'm not saying 2K is enough and we should all stop progressing, just that there "seems" to be other factors more important than racing the pixelrace.
It won't matter for small theaters but the marquee screens will be upgraded.For a small movie theater screen, you'd have to sit at least 12 feet from the screen to see the difference between 4k and 8k. We're talking like only the front row. So what would be the point of 8k? I don't even like sitting in the front row because you can't see the whole screen.
http://carltonbale.com/does-4k-resolution-matter/
I think the problem now is lenses being good enough for 4K and 8K, and storage, and whatnot. I mean lenses now you can't really have them wide open on F1.4 or 2 if you want the resolution to be good. Maybe that's is less of problem on bigger sensors closer to 65mm...The current and continuous pixel race is toward 8K. 4K is merely a pit stop.
