Adam J McKay
I am also looking to sell my Arri kit. Information below. I am hoping to get $3500 Canadian willing to deliver anywhere in Ontario at that price.
http://vistek.ca/store/ProVideoLighting/256586/arri-lighting-softbank-iv-plus-kit.aspx
Arri Lighting Softbank IV Plus Kit
This ARRI Softbank IV Plus 5 Light Kit includes barndoors, filter frames scrims, a softbox, clamps, light stands, bulbs, accessory kit, and a heavy duty wheeled case.
Key Features
The ARRI 150W Fresnel is a compact, lightweight fixture with great performance, tough construction and a 2" (50.8 mm) Fresnel lens. Superior optical performance and ARRI's die cast aluminum housing make this the perfect small unit for hair light, edge light or eye light.
300W Plus Fresnel
The ARRI 300W Plus Fresnel is designed to gather as much light as possible and direct it through the 3.2" (81.2 mm) low expansion, borosilicate Fresnel lens producing a soft, even field of light. The beam spread is 15 - 55°
650W Plus Fresnel
The 650W Fresnel features the same lens, reflector, housing and power cord as the 300W Fresnel. The beam angle in the flood position is 54°, and a narrow 13° in the spot position.
ARRILITE 750 Plus
The ARRILITE 750 Plus from ARRI is an enhanced version of the tried-and-true ARRILITE open face line. ARRI started with the basic design of the ARRILITE 800 and optimized the reflector to increase output 21% using a 750W HPL lamp which employs a compact filament that concentrates and augments light while increasing efficiency. The result is almost double the output. A redesigned one-arm stirrup instead of a yoke facilitates greater movement while the dedicated accessory holder allows use of Chimera softboxes without a speed ring.
Soft Light
The 24 x 32" Chimera Video Pro softbox provides soft, flattering light for talent and pleasing catch lights for reflective objects.
Light Shapers
Use the barndoors and scrims to alter the shape and intensity of the lights. The included filter frames are ideal for color effects filters or diffusion.
Light Spread
ARRI lights are renowned for even beam spread, high efficiency and superior spot-to flood ratio.
Accessory Kit
Includes a bag, clothes pins, bulb storage case, 3-outlet extension cord, and heat-resistant gloves.
Light Stands
Offer lightweight, yet sturdy support to a height of 8.6' (2.6 m).
Wheeled, Heavy Duty Case
The case employs a hard plastic shell, aluminum trim and latches and a piano hinge. It features interior dividers and wheels for easy storage and transport.
What's Included:
Key Features
- 2-150W Frensels
- 1- 300W Fresnel
- 1- 650W Fresnel
- 1- ARRILITE 750 Plus Focusing Flood
- High Output HPL Lamp (750 Plus)
- Barndoors, Filter Frames
- Scrims, Stands, Bulbs
- Accessory Pack
- 24 x 32" Softbox, Heavy Duty Case
300W Plus Fresnel
650W Plus Fresnel
ARRILITE 750 Plus
Soft Light
Light Shapers
Light Spread
Accessory Kit
Light Stands
What's Included:
- 2 x 150 Watt Tungsten Fresnel Light (120-230VAC)
- 2 x 4-Leaf Barndoor Set for Arri 150W Fresnel
- 2 x Filter Frame for 150 Watt Fresnel
- 2 x Lamp for 150 Fresnel - 150 Watts/120 Volts
- 2 x Full Single Scrim for 150W Fresnel - 3"
- 2 x Full Double Scrim for 150W Fresnel - 3"
- 1 x 300 Watt Plus Tungsten Fresnel (120-240VAC)
- 1 x FKW Lamp (300W, 120V)
- 1 x 4-Leaf Barndoor Set for 300W Fresnel, 125W HMI, 200W Pocket PAR
- 1 x Filter Frame for Plus 300, HMI 125W Fresnels
- 1 x Full Single Scrim for Arrilite 600, 300W Fresnel, 125W HMI Fresnel - 5"
- 1 x Full Double Scrim for Arrilite 600, Fresnel 300W, 125W - 5"
- 1 x 650 Watt Plus Tungsten Fresnel (120-240VAC)
- 2 x 4 Leaf Barndoor Set for 650W Fresnel, 200W HMI, 400W Pocket PAR
- 1 x Filter Frame for 650W Fresnel, 200W HMI Fresnel
- 1 x FRK Lamp - 650 Watts/120 Volts
- 2 x Full Single Scrim for 650 Fresnel, Arrisun 2, HMI Fresnel 200 - 6-5/8"
- 2 x Full Double Scrim for 650W Fresnel, Arrisun 2, HMI 200W - 6-5/8"
- 1 x Super Clamp With 5/8" Stud
- 4 x AS-2 Lightweight Stand - 8.5'
- 1 x Arrilite 750 Plus
- 1 x 750W HPL LAMP 120V AC
- 1 x Chimera Video Pro Bank (Small)
- 1 x 571197 Heavy-duty Location Case
- 1 x Accessory Pack for Fresnel Lights
- 1 x Ceiling Scissor Clamp with 5/8" Stud
