Are there any FD to M4/3 adapters which allow the focus to be view from the side?
Drcoffee
Are there any FD to M4/3 adapters which allow the f.stop and focus to be view from the side of the lens when mounted, as opposed to the top? Making it easier for a focus puller...
Jon
Interesting framing of the problem. Have you considered using a Follow Focus system? These have there own marking disks that can be viewed from the side.
i wondered if you could unscrew the silver FD part and rotate it 120 degrees until it meets the next set of holes on the black m4/3 part of the adapter, you would probably have to drill out a new hold on the side of the black part for the aperture pin.
... or you could get a print shop to print the lens focus details onto a thin strip of vinyl sticker, stick it on the lens :smile:
