Other: Are SONY HDC-1500R 444 and Sony HDC-2500 12 bit a sony f23 & sony f35 w: better s/n ?
BatVal
So I was looking into the Sony F3 and was super please by the image and then I went down the rabbit whole to 3 chippers and the Sony Ex3 which I though also had a pretty good image for the time and well I ended up with the HDC line.
The film Pina 2011 was shot with an HDC-1500 and Sony F3 I believe. There a glass house dance sequence that looks pretty good and I’ve always been a fan of broadcast cameras, grass valley etc.
Has anybody ever used one of these? And here is my question.. can they be used with out triad or fiber cable and without a studio or truck?
Can they be used without a CCU unit? Like a traditional broadcast camera wireless in the field? Could one theoretically be powered the traditional route be connected to a cinedeck and work? I believe the hdc-1500 is compatible with cinedeck and I’m assuming hdc-1500R also is?
I only ask because the sony HDC-1500R 444 (60’s signal to noise ration) and the HDC-2500 12 bit seem to be what I’ve always dreamed of. 2/3” 3 chippers with color and high s/n ratio.
Please please please tell me these heavy beasts can be used and function without triax or fiber cable and a tv truck!!
Even if they need the CCU unit can they be used without triax and fiber cables if one chose to do so?
https://youtu.be/F-cV74Mq7KU
The 4 HDC cameras of today also look phenomenal. The HDC series in general looks like my cup of tea but the triax and fiber cable to tv truck or studio is what’s bugging me. As well as the price of one but can they be used like an Eng broadcast camera obviously setup on a heavy tripod for narrative feature film work? Weight aside if I dealt with it
I can confirm that you could run and control the HDC-2500 from an RCP 1000 panel via the 8-pin remote socket on the back of the camera head. Yes you can run the head without Triax.
These cameras were basically used in the 1080i TV world. There were a variety of software modules available for these cameras to give you a variety of output standards. Basically, these cameras came as just "head" which you optioned up depending on your networks' requirements. Digging through one of my archive drives I found the following information. You need to install these modules to access the different frame rates listed. I guess these modules are still available from Sony Support. You would need to check that out.
"Optional accessories. You can add new functions and compatibility with other video formats by embedding the following optional accessories.
For details on optional accessories, contact a Sony sales representative or Sony service representative.For specifications or more detailed information on optional accessories, refer to the Operation Manual of each accessory.
HZC-UG444 User gamma-compatible software. Embedding HZC-UG444 user gamma-compatible software makes RGB 4:4:4 output possible.
HZC-PSF20 Support software for PsF format. Embedding HZC-PSF20 PsF format-compatible software makes creation of 1080/24PsF, 1080/23.98PsF, 1080/25PsF and 1080/29.97PsF formats possible.
HZC-PRV20 Software for progressive support. Embedding HZC-PRV20 progressive format-compatible software makes creation of 1080/50P and 1080/59.94P formats possible.
HZC-DFR20 Dual-speed software. By using the HZC-DFR20 dual-speed-compatible software, 1080/100i, 1080/119.88i, 720/100P and 720/119.88P 2× slow-motion recording is available.
HKC-TR20 Triax Transmission AdaptorEmbedding HKC-TR20 into HDC2500 makes triax transmission possible."
Remember in the lower frame rates these cameras only output PsF (Progressive Segmented Frame) not true progressive as there is no SDI standard for 23.98P, 25P and 29.97P. If you want progressive as opposed to PsF you would need to convert the output signals by removing the pulldown.
As nice as these heads were years back with their specified sensitivity of F10.0 in 1080 60i they pale in comparison with even the humble Z280 of today which is specced at F12.0 in 60p and F13 in 50p whilst achieving a very good 63dB s/n as opposed to the 60dB s/n of the 2500.
To deliver the best images out of those 2/3" IT CCDs you really had to use the very best B4 glass from Canon or Fujinon. $20-40K glass that is. For a 2/3" sensor you need to be pulling at least 100 Lp/mm (line pairs per millimeter) throughout the zoom range. Also being three-chip cameras the lenses needed to fully support the camera's ALAC compensation circuitry. This circuitry communicated each individual lens specific file info to the camera head to correct for CA anomalies which all lenses have to some degree. Something like this current model from Canon:
https://www.bhphotovideo.com/c/product/1149249-REG/canon_hj24ex7_5b_iase_s_2_3.html
Almost any lens will pass almost any spatial resolution, but the “modulation transfer function” or MTF, the amount of contrast that gets through at different spatial resolutions is usually better in lenses intended for higher-resolution applications, and the higher the MTF the sharper the pictures look and for a 2/3" chip camera only really good B4 HD glass will do that for an 11mm 2/3" HD sensor. I guess are you prepared to spend that sort of money on glass for an aging camera? Luckily you can pick up really good B4 "Cine" lenses quite cheaply even on eBay. Once you have shot with one of those on a good 2/3" camera you can see see the amazing difference in image contrast and sharpness and overall quality that can be delivered by a 2/3" sensor. Something like this set represents some of the best you can put on a 2/3" sensor: At an affordable price even.
https://www.ebay.com/itm/174540030329?hash=item28a3658179:g:4k4AAOSwB65frTod
Regarding the age of the 2500, or any three-chip camera of that age you really have to check the IR filter block that sits in front of the prism to make sure its not suffering from de-lamination. They are made up of a series of glass elements that are bonded together. As they get older the compound or "glue" they used to bond the elements together can start to deteriorate and cause nasty image distortions and softness. I've seen cases where new filter blocks were purchased only to find the "new" ones were suffering the same issues. They were "new" at the time of purchase sure enough but had been sitting on a spare parts shelf for years before being sold as new.
Beautiful cameras capable of beautiful images but buyer beware going down that route would be my advice.
Chris Young
Great Advice and thank you for the information. One of the huge benefits of B4 glass, at this point in time of modern large sensor cameras, is that comparitively speaking they can be bought for pretty decent prices. One thing I know for sure is that I am a deep focus shooter ie Deep Depth of Field and I don't really equate with shallow depth of field with cinema as much as I value mise en scene and staging the whole frame more. There is an old black and white Hamlet film with Laurence Olivier I believe that did some absolutely incredible things with deep focus and lighting, etc.
Most of my glass now is Fujinon or Canon HD cine primes. I have a feeling as the years go on, B4 glass will only become cheaper and more available second hand online.
So even if I am using a 2/3' 3 chip or single sensor camera, at most super 16 sized sensor or 4k down-sampled to 1080P I am doubling down on B4 glass for my kit and style of shooting for the next 15 years. This I know for sure and 100% it is just a decision I've made. Even if that means adapting my b4 glass to non prism cameras down the road, or even full frame cameras if for some reasons that attracts me. I am spending the money on the adaptors now to give me that flexibility in the future.
Your response is super helpful. I've always been interested in learning more about how this technology works, sensors, parts, CCD vs CMOS, trends limitations and possibilities etc. not even just for a camera I might be considering purchasing but also to have a technical perspective or understanding how parts to everything work so I know what can be done, has been done, for what reason or not, and what is possible to do. so Maybe even sometime way in the future a light bulb might go off or a subtle minor detail or understanding of a relationship dynamic can allow me the ability to do something unique or different with the execution.
Like even you mentioning 100 Lp/mm (line pairs per millimeter); that is something I've always been interested in learning more about because I want to actually be able to look at and understand sensors between different cameras and hypotheticals vs execution vs marketing stats or advertising companies will engage in. I picture it like a mechanic on a car. I want to understand the engines and nuts and bolts of the cars to make my own evaluations and judgements outside of what the car salesman is selling.
Understanding of all these different elements is ultimately what I am seeking.
Thank you so much for the response. It's super informative for me!
I also find it crazy that there is still modern content I can watch today that I don't like whereas I can watch something shot on an F35, F23, Sony Ex3 even , or Sony F3, or some of these other cameras during the peak of the CCD era and like it better.
I'm 32 yrs old. If it was just about image quality and the quality of the tech that should not be possible. But other factors are at play, capitalism, trends, marketing, cost of production vs profit, size and convenience and so on. Many factors and trends actually and that is why I like to question and ask what is really happening here and what resonates with me personally?
Similiar to modern day cars vs some older vintage cars and changes in methodology and build quality and so on. To your point your right in that we've seen advances but there are still parts of me when looking at an image that still sees certain images as good enough if not better from the past to the present and of course vica versa from what we see now in some cases vs the past. But there are always those intangibles and that are more difficult to precisely quite describe the why of it all resonating.
