PanasonicNZ
If you do longform (continuous shooting) your clips will be split into 8GB chunks by default anyway - one card goes onto one disc if you use dual layer DVDs. For shorter shots, you will have as many sets of files as the number of times you started/stopped the camera. You can easily select clips with P2 viewer (free application that comes with the P2 series) and combine them into appropriate volumes. Again, I used DVD as an example because it is available now. Panasonic is part of the bluray thing, which is a data format. I don't know release dates or other details, I'm pretty isolated here, down-under. IMHO, in less than 12 months there will be another solution out there. The big problem is not the technology, is pepole's stuborness to use something different which is outside their comfort zone, even though the new stuff is so much better.
