AndreeOnline
The release note for FCPX 10.4 lists support for Canon Raw Light – with additional software from Canon.
Lot of other goodies as well.
Actually, there's less support in FCP for raw than there is in CRD.
Like Resolve, Final Cut Pro appears to be rendering the raw as Clog2 without providing any options to change raw file settings. I tested this by taking a raw clip and using Canon Raw Development to transcode to Clog2 ProRes, then I did the same thing to Clog3 ProRes. I put all three clips on a timeline in FCP and turned off the LUT for each file. The raw file and the Clog2 ProRes look identical; the Clog3 ProRes file looks different, including less noise in the shadows.
I noticed that by default, FCP applied its Clog2 LUT (that comes pre-installed with FCP) to both the raw file and the Clog2 ProRes file; it applied the pre-installed Clog3 file to the Clog3 ProRes file. I was also able to easily load new custom LUTs into FCP to use with the C200 footage.
Here some screen captures that show what I'm talking about: https://imgur.com/a/Oq1rg
I'd like more options for altering raw in FCP or Resolve or Premiere - mainly while balance - but I personally don't find it to be a big deal. Eliminating the need to transcode to ProRes is great (and raw files are actually smaller) and if I've really blown the white balance, I can still use Cinema Raw Development and the ProRes workflow.
…and if I've really blown the white balance, I can still use Cinema Raw Development and the ProRes workflow.
This is good news. I have the feeling Resolve DOESN'T default to any of the Log curves, but uses something else.
It makes sense to default to the flattest curve and it should be easy to transform that into anything we need. Even better would be a little panel like RED has to change the settings directly of course.
Or, just use the white picker in FCPX or the white balance tools in Resolve.
How would you transform them, Andree?
This is great news! Adobe could probably ignore DaVinci and Avid, but with FCPX also adding Canon Raw Light support they'll be the only major player without support and will have to add it to Premiere.
So if one wanted to utilize CRL in FCP X with this new plug-in as C-Log 3, there is no way to do that, short of using CRD and rendering Prores CLog 3 files out and importing them into FCP X? How would you transform them, Andree? The panel sounds like a very useful idea. Hopefully development will continue with the FCP and Canon teams to build more functionality into CRL in FCP X?
I work at Adobe 'though not in the Premiere team. Releasing new features is more about what customers are asking for and our existing product release schedules than what the competition is doing. That isn't a comment specifically about C200 support - it's just what I've seen in the (long, long) time I've worked here.
If you take a C200 raw file and put it on the timeline, FCP will apply its Clog2 LUT to the file. If you put a CRD-transcoded Clog3 file on the timeline, it'll get the Clog3 LUT. What's interesting is that both files will look exactly the same with the LUTs applied. Even the noise in the shadows - which definitely looks different with the LUTs turned off - looks exactly (even at 200%) with the LUTs on.
If you shot those clips after each other with the same exposure value it makes total sense.
