How about polarizing filters? I know they make things look richer, how do they work with video stuff?
Thanks for the resource. So it looks like they could be very helpful for videography, if you know how to use them.
I have owned and operated over 25 different video and still cameras used in my studio over the past 29 years, from Broadcast to Consumer. Every single one of them has had a UV filter for protection. You absolutely do want to protect your lens. Accidental damage to the lens surface is nearly impossible to undue.
Interestingly, the glass filter I had on the 14-140 kit lens (MC Sigma) got scratched. The most likely culprit is the cap somehow loosening up in the bag and touching/scratching the surface. This does not seem like the problem that will affect lenses with a relatively small front element, like the pancake(s). In any event, I would rather replace the $30 filter than a $700 lens.Now, most of us aren't using $5000 lenses all the time, but the point still holds in my opinion. Unless you get the very best filters (and even then) your image quality is going to suffer - whether or not its noticeable in video is something else, but cheap filters (even moderately expensive filters) can add reflections, change the flare characteristics and can add chromatic abrasion. I don't see any reason to use UV filters - lots of folks say they are there for protection, but I don't think many folks realize how hard you have to hit a piece of lens glass to cause it to break/scratch - if you hit the front element of the lens that hard, you're going to do all kinds of damage to the lens itself, and if you do that with the filter on, you're going to bend the filter and screw up the filter threads too...and if you are further successful in actually breaking the filter...well guess where all that broken glass is going?
It's going to be driven right into the the front element of the lens itself. Ouch.
I say only use filters when you need them, then take them off - if you're shooting video you need neutral density filters (good ones) and probably a polarizer on hand - buy good ones in a large size (77mm) and then get step up rings for all your lenses so you can have one good set of filters that will work on every lens you have.
