GH5 Any Insight what this is
flinty
https://vimeo.com/224022511
The vimeo wording pretty much sums it up,the original clip looks identical,7 clips around 5m,not the first,i did not realise as i did not see anything in the viewfinder as i recorded,all fine after it stopped,i recorded 1hr 20m total with my GH5 and 14-140 lens.Any help Will be apeciated.
I would say it is a flare from light coming into the lens. It looks like you had some harsh sunlight just over the edge of the building and some was sneaking in at the right angle or bouncing off of something that was causing it to dance around.
Outside of that maybe the GH5 has a "paranormal mode" we do not know about! :)
Looks like a reflection coming from someone's watch....perhaps another camera lens...the jitteriness in the reflection could be from your lens too though as it's the sensor that's stabilized...
I agree with Bassman. But I'm guessing it was a stable light reflection and you had IBIS on which makes it look like it is bouncing around.
Thanks for the replys,its strange it never showed while filming and also as i said only 7 clips had it and others in the same position did not.Could be paranormal eek :evil:
I also would think that what you see in the LCD monitor or GH 5 viewfinder cannot compete with what the camera records...as the "reflection" is not in all your clips, it may also suggest a slight change in the sun's angle or the angle of what caused the reflection.
Of course if it's paranormal, the Enquirer will probably pay you handsomely for the omen in your footage...save that memory card in case something happens������
Its in the safe :smile:
