cyvideo
Had to come up with a base working LUT for extra footage to match an on air grade. An S-LOG3 LUT I came up with to match that on air final grade. Three clips in each sequence. The first clip is an S_LOG3 clip. The second clip is the same clip but with my LUT on it. The third and final clip in each sequence is the same clip but pulled straight from the final broadcast grade render of the program. As always, you can often get close, but some final tweaks would need to be done to get close to 100%.
Can be viewed here:
https://drive.google.com/file/d/1qFM5mfMT07izxWTSEWSnnlzOJTBkzvdW/view?usp=sharing
Chris Young
![SLOG Cine to s709 comp [small].jpg SLOG Cine to s709 comp [small].jpg](https://www.dvxuser.com/data/attachments/118/118114-fbacfaf696068b1ea0edcf653bf399da.jpg?hash=-6z69pYGix)
Can be viewed here:
Chris Young
