Anamorphic question with a 50mm lens
jondoe
I've read most of the "Anamorphic Shootout" thread and got a lot of insight about anamorphic adapters however I'm still intimidated about which one to purchase. Doing a ebay search (Anamorphic Ebay Search) on Anamorphic lenses brings up a slew of lenses ranging from around $100 bucks to thousands. Below are some of my concerns that hopefully someone can help me with before dishing out money on it.
1. Compatible with my camera. Some adapters are too small for my 50mm lens.
2. The focus option. A friend of mine who owns a lot some Anamorphic lenses explained the focusing of the actual lens and the anamorphic lens. So will i not be able to use a follow focus with an Anamorphic lens?
3. Similar to the look of the Sankor 16f. There are a ton of options for Anamorphic adapters but which is the most similar to the Sankor 16f?
4. Price - Ideally I'd like to spend around 300-400 (or lower for one). Is that possible?
5. Can I use it on a wide angle lens too (like a tokina 11mm or similar)? If not, its fine but just a question i wanted to add.
Hi there,
I ran across your post by chance (doing a search for anamorphic lens information) and I thought I might be able to answer a few of your questions.
1. Yes, some of the affordable adapters out there are too small for larger lenses. Many of those were made for 16mm or 8mm cameras, and are not good options. Some of them might be useable using step down adapter rings, but then vigneting will be an issue (maybe something to test with the GH2 teleconvert feature.)
2. There are 2 main types of anamorphic adapters as far as I can tell. Focus-through (you just focus your prime lens and leave the anamorphic adapter alone) and adapters with self focus. The Kowa and the Sankor need to be focused along with the prime, which makes them hard to use unless you are working with fixed focus shots. Out of the ones that are focus-through you have low end ones (Generic Anamorphic adapter, Optex, Century Optics, Panasonic LA7200, Soligor, etc) and then you have higher end variants (the main ones I'm aware of are the Iscoramas and the Isco Anamorphots. I'm not sure how the Iscoramas work, but they have a special optical formula which allows them to offer very good quality and still be focus-through (I think.)
The cheaper focus-through lenses are an option, but they are tougher to match to a lens that will provide good results. Typically they soften towards the edges of the frame, and also tend to exhibit some chromatic aberration. They normally work best with longer focal lengths and relatively small apertures. I've seen videos taken with the Generic Anamorphic on DSLRs that look great, and some that don't look that great because they used short focal range lenses at wide apertures (it looks like the generic works best on the GH cameras with lenses around 50mm.)
4. For the price you want to pay your only two choices are: Kowa/Sankor/Proskar or something like that, or the Generic Anamorphic adapter. If you want to shoot stuff that will need focusing during a shot I'd say go with the Generic Anamorphic unless you have an assistant that can work the focus on the anamorphic lens while you work the focus on the prime (or something like that.) The Generic Anamorphic goes these days a little over $400 (one just sold a couple days ago for $432 in the auction site) and it imposes some limitations on the lenses and apertures you can use, but you can get really nice results with it.
5. Wide angle lens? I'm afraid not. At least not with the Generic Anamorphic, and very much doubt you can make that work with the Kowa/Sankor/Proskar variants either.
As you can see, anamorphics are a challenging subject. Sure you can get nice results with them, but they introduce a lot of complications (not to mention cost.)
This is a nice video showing what you can expect from the Generic Anamorphic with a 7D:
Notice the use of 50mm lens. If they had use a 35mm lens with wide aperture I can guarantee the quality would have degraded quite a bit.
The flares can look very nice, as you can see. I'm not too sure about the bokeh, but I think I can see some of that anamorphic nicely distorted bokeh as well.
