Darkline
Is it me, or does the image look badly keyed? not around the womans hair but the sides of the car are pretty bad... it definatley shows huge erosion of the bonet and dark blocks that are keying/semi transparent artifacts.
The bonet reflection is now brown, which in my experience would be where the greenscreen has reflected in the bonet and part of the green colour has been keyed away unfortunately with chunks of the bonet on both sides of the car (right side looks worse)
You can clearly see the reflection of the couple in the bonet, and the muddy brown is the reflection of the greenscreen behind the subjects... This produces the semi- transparent artifacts/colour blocks that have also fallen into the tolerance of the green key and been partially removed accidentally.
Hence the eroded edges of the car itself (these look like black patchs as you're seeing the background image come thru to the foreground image) This shows up the blocks of green (now brown) colour, which I guess would be the DVCPROHD compression on the green channel. Interesting to see.
Some of you may think it doesnt look that bad, but trust me, if that background was anything other than a very dark blue, you'd see it come shining through both sides of the bonet with flickering chroma artifacting.
That said, I'm not making judgement of anything on this singular image; it could be just a bad attempt at a key..... maybe a 2 pass key process could have handled it better (one that isolates the green reflection and hue shifts it). It's interesting to see tho and I sure wouldnt have posted this as a first good example of HVX keying abilities with all that artifacting.
