Grassybutte
Hi there,
Bought this for a documentary I was producing over a year ago and barely used it because we went wireless. It's in pristine condition, and it goes for over $500 plus tax new. I hope someone sees a good deal and gets some use out of it.
I'm in Vancouver, Canada. I would like to sell locally if possible.
Thanks for you interest.
Ian
Below is some info and specs I got off the web:
Quickpole booms (QP) are constructed using high modulus carbon fibre tubing with 1.5 mm wall thickness, giving excellent stiffness for lengths over 5 meters. Due to the wall thickness and carbon fiber crosswinding, the tubes are very strong in the compression mode and can be stood on without breaking. Standard booms are available in numerous lengths with 30 mm dia. outside tubing. A 35 mm dia extension is available for long booms, and for the small ones if they are to be used in a Manfrotto stand. The extension has the added advantage that it can be extended like the other segments. The extension is fitted like an extra segment and can be left on the boom.
Features:
Length: 154 - 540 cm, Weight: 1000 gr.
The industry's strongest and stiffest carbon-fiber tubing
Machined, stainless-steel 3/8" threaded tip for long life
Simple, secure screw locks with extended threads for lifetime durability
External aluminium collars for additional tip strength
Internal spacer ring of nylon felt for smooth action and easy servicing
Special collet retention pin prevents intersegment twisting
Very low transmission of boom "handling noise"
Booms do not get tight when cold or wet
Booms can be quickly disassembled for cleaning or servicing
Ian
Features:
