Am getting more than 100 mbps
blues
my settings are
AVCHD 50 44H 33L 56 60
GOP 5
native 24p ticked
and I am gettings 115 megabits/s
I used Mpeg stream to deinterlace...
is this possible? am using the class 6 sd card
why not....looks smoother to me.
anyway the settings looks stable so far. the low GOP seems to work.Does that mean the file size will be bigger since its less compression?
I think the point is that if you're recording in native 24p then there couldn't possibly be anything to deinterlace. The difference you're seeing is either (1) the result of something other than deinterlacing or (2) purely imagined or (3) the footage from the camera is not really native 24p.
The other issue is that if you're converting the AVCHD file to mpeg with MPEG Streamclip, then measuring the bitrate of the mpeg, you're not measuring the bitrate of the original AVCHD clip that the camera wrote.
I think the point is that if you're recording in native 24p then there couldn't possibly be anything to deinterlace. The difference you're seeing is either (1) the result of something other than deinterlacing or (2) purely imagined.
Werd
why dont you all try it and prove me wrong!!!!!
the original after log and transfer dowload from FCP with AVCHD preference prores 422 says 116 mbps
then get the free mpeg stream and you will see the option deinterlace still present so check the deinterlace option and click make a movie option
the new bitrate/sec is 115mbps
then compare the image...the de- interlaced clip is smoother.
I suspect the 24p option is realy not the real thing, you still need to de interlace.It appears in Jes as well. but in jes the option inverse telecine disappears meaning the 24p checked is working on another level.
I suggest you try the settings and go thru the process and tell me if I am doing something wrong.Thanks
BTW I use the latest ptool 3.40D and my camera recording option is in AVCHD in FHD mode not mpeg
Unlikely, I've been testing a class 6 card and found that around 28mbit is the maximum stable bitrate you can use. 32mbit works most of the time but will occasionally crash out with the card write speed error on demanding subjects.
Once you log and transfer in FCP, you have transcoded the clip. Thus your mbps will be different as it's likely you are now using a codec that's FCP friendly. If you want to see what the real clip bitrate is, you need something that can peak at the MTS file on your SD card. MediaInfo Mac will let you get bitrates right from the MTS file. Try that, and you'll see you are not getting 100+ mbps with AVCHD. The AVCHD tends to choke the card (class 10) right around 54mbps or so.
Deinterlacing progressive footage really makes no sense btw.
please try it as I am very interested.I have been using it with a class6 card and for 3 days now I have not experienced a crash.looks good so far......am in the tropics so the different light contast is severe...but it holds.
ok you are right,it says 27mbps when original MTS via media info and I see it varies from shot to shot. but it still does not answer why the deinterlacing option still exist when the mpeg stream is used. please explain thanks
if you look where the deinterlace options are in mpeg streamclip.. you'll see it say's "deselect for progressive movies." It doesn't prevent you from selecting deinterlace, but it clearly says not to. :)
