egproductions
After shooting with Lekos 750w and 525w, the head is very reasonable in weight and size. The PSU adds the slight majority of the weight but even both together seems to be more portable than a leko. The noise levels confirms that this light is only good for outdoor use, through a window, as a fill in large spaces, or any other application where noise from the light won't be a big concern. I wouldn't use this light as a closeup key light since it will be loud and you will make you subject pretty uncomfortable due to the brightness of the light even when diffused.
You won't burn your hand touching the housing of the light, you might start burning your fingers if you actually touched the frosted dome of the light for more than a second or two. The website states "great care must be taken when applying gels to the light as the front of the PAR reflector can not be covered blocking air circulation on the front of the LED" I don't think a gel will burn if left in front of the lights reflector but I can't speak for the well being of the light (I would personally take the risk as it didn't seem to get too hot).
Something to keep in mind is that the light is still very bright even when fully dimmed.
