Barry_Green
Moderator
The ones in the price bracket I've been following, which is the 7D, 5D, GH1, and K-X, all do the same basic thing, to one degree or more. The GH1 doesn't appear to do the severe color contamination that the 7D and 5D do, but the amount of aliasing is still quite substantial.Thanks for the great article!
From what I've seen the aliasing on the Canon 7D appears worse than on the Panasonic GH1. So is it really fair to lump all the HDSLRs together?
Incedentally, this is what the HMC40\TM300 has, 3MP per chip. But these are three-chip cams, do they use Bayer pattern? Do they NEED to be 3MP each?That's what I would consider the ideal. But not 2mp, you'd want at least 3mp. You have to factor in the resolution loss due to the Bayer pattern and demosaic process, so you need about 3 megapixels to deliver a truly sharp 1080p image.
W/regards to Red, the Red One has been used for high-end still photography (for example Megan Fox's spread in Esquire) so whatever balancing act they've come up seems to be working (or at least 'good enough').
