downsouth said:If only two cameras existed on the planet, and the prices were equal, which would you choose for your business/hobby.......and why!
Panasonic DVX100B or Canon XH-A1
Jeff
__________________________________________________________
Yes, it did. It said, and images were posted to show, that you can max out the colors to pull some punch into the XHA1 image, but even so it only begins to approach the HVX's default settings. The HVX can be pushed much further (if that's what's desired).jade8472 said:The review said nothing about how they compared after adjusting the settings in camera
That is exactly true. There's no single overriding case of "better", there's only what you prefer, and that's subjective in all cases.(and such a comparison would not have been possible in any case because there's no established benchmark on which is "better").
No, it isn't. It may be everything you need, but it isn't everything the DVX is. DVX includes manual zoom, cinegamma, is at least a stop faster, has precise repeatable focus, better audio, individually controllable audio channels for line/mic and phantom power and routing one mic to both channels, two levels of zebras, zebras and peaking at the same time, etc. The XHA1 has many things to it that the DVX doesn't as well. They're not the same, and the XHA1 does many things the DVX doesn't (including high def!) But to say that it's "everything the DVX is" is just not true. Might be everything you needed from a DVX, but that won't apply to everyone.jade8472 said:A1; it's everything the DVX is, with HD and 16:9 capability.
Including two Oscar-nominated documentaries! All these cameras are good enough, and buying a better-quality camera isn't going to be the difference between success and failure anymore; just buy the one that's right for what it is you do. Each has different features and capabilities.Sirocco said:The DVX (in good hands) has help produce award winning projects
No indication whatsoever. I've been nagging for exactly this for a long time, and have not gotten any encouraging feedback that it's coming anytime soon.So is there a AVC-HD-DVX waiting for us next month?
Barry_Green said:As compared to the DVX, I'd say the XHA1 takes six steps forward and two steps back. But with the aggressive pricing, it's the better buy for most circumstances; a prospective owner would have to look at the list of things the DVX does that the XHA1 doesn't and determine if those were dealbreakers. If they can live without those features, get the XHA1 by all means. If the user can't live without those features, the XHA1 is not the better camera for them.
Hi Barry,
Would you please give an example (or two) when you would use both the line and mic settings? On the DVX, how would you route one mic to both channels? If I had 2 separate mics plugged in to the A1, can I set both to different levels?
Thanks!
