I just returned the AG-CX-10 I got. I had high hopes with a low bar. I loved my retired AG-DVC30 (standard definition camera) and was hoping it was the HD version of it and it is -- almost. The size was similar and the zoom range was similar- 24x optically which was the reason I bought it. When compared to my AC130/160 it was/is a very soft image when zoomed in about 60 percent and onward. The file I was using was AVCHD 1080p PS (The highest quality 1080p) -- the same file type as my AC160. (so I didn't mix file types on my timeline) Not sure how this is possible since reviews were so glowing.
The image might be sharper using a different file extension type (etc...) but I would expect to be near equal to my older AC130/160. Heck the CX10 has a larger chip. When zoomed in the whole picture seemed like it's shifted and soft. no sharp detail when compared to equal file type from my AC160. When zoomed out it looked fine but my line of work I zoom in on action. And no the camera didn't focus on something else. I had a fence line of at least 50 feet in the picture and none of it looked like it was in 'focus'. Ohh - all footage taken outside with plenty of light.
The things I didn't like about it:
1) Manual White Balancing. It is a royal pain to setup. You push the white balance button and it just rotates through Ach, Bch, Preset. And you need to program some other button (USER1-11) to initiate/make a white balance (and black balance) manual button. And even then I find it off a little. I never really found this camera's white balance user friendly (for this long time Panasonic users.) WHY CAN'T I JUST HOLD IN THE WHITE BALANCE BUTTON AND DO A WHITE BALANCE??????
2) Manual focus when zoomed it is quirky. The ring feel more like a digital thing than an actual lens movement.
3) Some User Buttons are easy to hit when you don't intend to.
4) top handle zoom button is a reallyyyy slowww zoom. This can be a plus if you're looking for a "PBS" zoom but really bad if you're looking for a "MTV" zoom. The side hand grip rocker is fine and remote zoom control through LANC worked fine although I felt it took more time to zoom in verses zooming out.
5) NO battery charger. It is in-camera charging. WHAT?... a "Pro" camera you can only charge in-camera unless you want to spend $200+ on a separate charger. ARG. Stupid, all the other lines the power box has a charging port on it and the ability to run a DC cable to the camera. (side note I don't own a 350) So be prepared to pull the camera out of the bag, evefr time, to charge the battery OR cough up $$ for a charger..
6) DC cable does not lock in place in the camera. ie no pro-connection. PRAY your camera operator doesn't tangle himself up with the cable because it will slide right out of the camera and you'll lose all power. which brings me to #7
7) AC cable plus DC cable all connected to power supply may be only 5 feet in length. Wayyy to short if your tripod is set for more then 4 feet in height. One thing to note: DC cable is built onto the power supply so it won't come off.
8) the Standard definition recording - none. Bad for Deposition videographers which only buy Panasonic because of the time date stamp function built in.
9) the 720p recording is a very low data rate (8Mbps). No 25Mbps Only 8Mbps. I know most people probably won't use 720p but I think some people would use it if it had 25Mbps.
10) The AGC text at the end of the audio levels has nothing to do with Audio levels. WTF?
11) the menu is very confusing. One example:You no long adjust file type/data rate recording under the recording menu. You do it under some other vague menu option.
12) you have to touch the screen to make changes. Which isn't terrible unless you're outside with a lens shade on it and can't do anything without taking the hood off and then struggle to see the screen when you have direct light. The screen is bright but not an ideal thing. And yes you'll be wiping the finger prints off it.
13) to use your mobile device to adjust your camera --- you need a wireless router to connect through. NO direct connection like GoPro. (so 2010-esque tech design) WORTHLESS!
14) Playback is labeled "thumbnail" on camera. WHY??? the owner's manual section called "playback" is all about what you do under the "thumbnail" button.
15) a programmed USER button for 'deleted last recorded clip' is a dangerous function of a easily accessible user button. (not sure if it asks to confirm but either way it scares me)
In short: look over the PDF owner's manual (download) prior to purchase. Look very carefully. for $2600 I'd tell you to pass unless you're looking for a wide shot lock down camera or closeup interview camera. Only huge plus is the P2 recording if you're looking for it. 4:2:2 is a smart thing to include. If dropped below $2,200USD then I would say it would be worth looking at it knowing it's limitations.
PS sorry about typos or sentence that don;t make sense. sorry I'm not good at proof reading.
