Panasonic AG-AC90 Resolution MTF50 Tests
I just completed resolution testing using the Imatest software. MTF50 resolution was measured at the center of the image at three different aperture settings, for two different zoom lengths. The readings were taken in both horizontal and vertical directions, the high and the low readings for each were thrown out, and the rest were averaged. Numbers thus obtained are usually lower than those reported using visual interpretation of ISO12233 charts.
The camera was tripod mounted. Each time a new measurement was taken the image was refocused and settings locked before the capture. Stabilization was off. The recording format was 1920x1080/p60 AVCHD.
The software normalizes the MTF reading to a standard 2 pixel radius for sharpening so that effects from in-camera sharpening are negated. Measurements are given in (LW/PH) line widths per picture height, sometimes referred to as "TV Lines." Readings above nyquist frequency are invalid or represent false detail or aliasing. A perfect MTF50 score is 1080 horizontal, 1080 vertical.
MTF50 result for Panasonic AG-AC90, overall score:
Horizontal: 1048 (LW/PH)
Vertical: 868 (LW/PH)
Comments:
The numbers are about on par with best HD cameras I have owned and tested including the Sony EX1, the best being the Sony PMW350k which is slightly higher on the vertical, and far above other cameras including the Canon 5DmkII, XH-A1, HV10, Sony Z1.
The tests were conducted in accordance with my usual methods from 7ft. It is not possible for me to get far away enough to test telephoto performance. The two tested zoom ranges were Z00 (fully wide), and Z13. The apertures chosen were f/2.8, f6.4 and open. Perhaps the best all around performance was at f/6.4, approximately 950-1000 tv lines both horizontal and vertical. The poorest averages about 825 lines vertical at aperture fully open. The variances from f/2.8-6.4 are unremarkable. The best vertical is at Z13, f/6.4, 1036 lines, and the worst horizontal 969 lines Z13, f/2.8. The best horizontal readings were above the nyquist at 1080 lines, and occurred at several settings.
Comments:
