if i do that im going ot have to invest in a slew of cards lol.
right now i own 2 Sandisk Extreme 30MB/s class 10 16 gig
5DtoRGB. It is a must, my friend. It sounds weird, but it works, and it works very very well.
Try it out, do some comparisons of course!
What's the benefit?
This is the benefit:
Before
After
Those are nostalgia, guessing between f4 and 5.6.
What's the benefit?
Before
After
Oh... so gravy.
Cory, also, the 18-85 was out at the moment. I havent' forgotten.
I cant seem to see the 2nd pic...What's the benefit?
Before
After
from my old post:"I've noticed that the MTS importer in After Effects, for example, will import clips as broadcast range, not full range H.264. This may be appropriate in most cases since I suspect most cameras shoot broadcast range (16-235 in 8 bit terms), but I've noticed clipped highlights in some files. My feeling is that if there is indeed information up there (above 235), it should be retained. However, this can break compatibility with After Effects and Premiere. I guess I'll add an option that allows you to force the transcode at either broadcast range (16-235) or full range (0-255)."
its most likely the mts thing. i think this can also possibly happen on mac too.That is kinda odd as the Canon 5d/7d shoot also at 0-255 levels and they display perfectly on Premiere and After Effects. So what's different with the GH2? Is this a mac thing?
what i do on my af100 footages to get the same 5Drgb result isNo, I'm on a PC. I just find it too contrasty. So the 5DtoRGB helps flatten the image out the way i like it.
