I was never able to get this to work! I tried with 3 different monitors. When the shuttle is connected to my AF100's SDI if I connect a HDMI cable to the shuttle it wont send any video out. Not live feed, not playback. I have no idea why. I know you have to press the stop button to toggle and all, but it will not work. Frustrating.
That is odd? Is the firmware up to date? (Not that that should matter), I find it works fine even with 24psf being passed through to the DP4, it does require that stop button being pressed though and there is maybe a 5 second delay to it coming through.
Cables all ok? If so you might have a dud and should get it replaced under warranty, or insurance if you now "accidentally" drop it![]()
Do you ever use anything but 24psf? Do you record interlaced with the shuttle?
If I switch 24psf off the pass-through works. But this is useless for me because with 24psf off the camera only sends out interlaced and I don't want to record interlaced. I know you are probably thinking the problem is that my monitors don't work with 24psf. But it used to work with the EX1 24psf just fine.
. . . I want the best image quality out of the camera too . . .
Not to hijack the thread but having shot my share of "best image quality" (and enough stuff that was hidious), I found my best image quality comes from framing, focus, and lighting, and sometimes the story, depending on what I'm shooting.
It's been a while but I'm just thinking back to the days when I thought that owning an expensive camera made me a "DP" and that more or better equipment was the "miracle" of great shooting. Not talking about anyone here, I'm just say'in . . .
After reading this and other external recording threads for the AF, I wonder- is the general consensus that a 10bit 422 Recorder (samurai, BM shuttle):
1) will not have any visual/perceived color improvement (when compared to the same shot via the onboard AVCHD)
2) can show a marginal improvement when trying to key out a green/blue screen in post (because of the 422 color space)
3) can show a marginal improvement when trying to heavily grade a scene in post
4) will not show any visual/perceived resolution improvement, unless its a high motion scene like a running stream of water or blowing leaves on a tree (because of the higher bitrates)
I read so many conflicting reports of improvement vs no difference seen. Some people in other threads claim no difference- and to prove it they record a static medium shot of a shampoo bottle (duh?). Does anyone know of any examples of where the codecs are stressed, or where someone has graded to the point of artifacting when comparing AVCHD vs an external recording?
- the noise in low light scenes, and resulating softness in AVCHD is very noticable when A/B'd with DNx/ProRez when displayed on a large screen - we did a test, and even the director's 7 year old son picked out the AVCHD instantly (and unfavorably in a way only a 7 year old can be) in a blind test on a 16" screen hit by a Christe2K projector1) will not have any visual/perceived color improvement (when compared to the same shot via the onboard AVCHD)
- it depends upon your tollerance for tearing edges, one man's "it's fine" is another man's "complete garbage" - are you delivering for youtube? prolly not a huge deal, delvering for HD broadcast or theatrical? Uhhhhh.. yea... ACVHD's pretty much garbage, even DNx/ProRez is suboptimal.. i go uncompressed for that stuff2) can show a marginal improvement when trying to key out a green/blue screen in post (because of the 422 color space)
- Alot of gradeing is keying really, using secondaries IS pulling keys, the diffrences are instantly appereant3) can show a marginal improvement when trying to heavily grade a scene in post
- Noise, cars moveing through frame, steadycam, pogocam, noise, fast moveing handheld, danceing, noise, any time the camera or the subject moves quickly(ish) and/or there's noise, add low light and fast moveing camera and even my grannie could see the diffrence on a Dolby PR4200 or a 16' screen hit by a Christe2K projector before gradeing starts... it only gets worse from there.... but you might not see any diffrences watching a mightly compressed a clip on youtube, does not mean it's not there - just means the delivery medium masks it4) will not show any visual/perceived resolution improvement, unless its a high motion scene like a running stream of water or blowing leaves on a tree (because of the higher bitrates)
Here's the Samurai on my RED.
My Acam rig with the BMD Hyperdeck on a WestSideAV baseplate / rear plate, everything (Camera/deck/EVF/7"mon) runs off one Vlok Switt all day long with more than 50% in reserve;
-My Acam rig with the BMD Hyperdeck on a WestSideAV baseplate / rear plate, everything (Camera/deck/EVF/7"mon) runs off one Vlok Switt all day long with more than 50% in reserve;
I would guess that's mainly the shoulder set up with the EVF? Looks pretty balanced for shoulder mount.
Bob how long does I take to get this back to a balanced tripod setup?
