That's what the AF100 does, right out of the box.Ok, so the end result I'm looking for is what you get when you slow 60p down by a factor of 40% in a 24p timeline.
Yes it does.So does the AF 100 write 60 singular images to the card every second at 1920X1080?
Well, see, there's the confusion then. What the TM700 does is record 60 images per second for playback as 60 images per second. In other words, the "live" look -- the "video" look. What the AF100 does is record 60 images per second, for playback at 24 frames per second -- the slow-mo film look.No worries with playback, I just want to know what it's doing from second to second...
That's not what the TM700 does. The TM700 does it "live". The AF100 does it slow-mo.Ok, now I'm quadruple confused.. I don't know of a soul in the indy film world that would ever shoot anything above 30P for the purpose of displaying it at it's native standard.. I guess I need to check myself.. Whenever I say 60p, I'm really saying "the lowest acceptable standard of smooth slow motion"....
No, in fact it already has 60p for the purposes of slow motion. It's already come to fruition.Correct me if I'm wrong and in no way am I trying to insight an argument but, is it safe to say that if 60p for the purpose of slow motion is nowhere near happening in the broadcast market ( AF 100 = Broadcast Market ), that higher frame rates are worlds away from coming into fruition?
Because numbers sell. Same reason camcorder manufacturers used to put "200x digital zoom" and then "300x digital zoom". Bigger numbers = more sales.This also begs to ask.. Why would the consumer division even put 60p in the $800 Consumer camera the TM700 is?
Yep. See above. Numbers sell. But you can't actually USE it for anything...Not only is it 1920X1080 60p able, from the internets POV, it's the strongest and most advertised selling point.
I too was surprised to see the tm700s 1080/60p mode.
The thing that strikes me most about the little camera is the detail. The images in good outdoor lighting are incredibly sharp. Blows my HMC150 away and I'd say it's comparable or maybe even a little better than the HPX300 we use at work.
I'm not saying sharpness is everything, but still, surprising how a tiny 'consumer' cam is able to render so much more detail than the HMC/HVX/HPX line of prosumer cameras.
Hey,
I've shot this way, using 1080 60p as my base standard. But it was more an experiement than anything else. You need to remember the challenge is not just the picture, but audio as well. We had to record to a Cantar X2 and do some "interesting" things in post. Bottom line: It's cool for certain things, but there is a reason it's not a standard playback. It actually reminds me a little of "Showscan" for those that remember it.. Showscan was a huge deal back then, think "HD for film".
Now here's the trick: I had to use a RED ONE to pull this off.. You said the little camera you had did it? That's cool, but there's a lot to makinig this something you can actually "show". Whatever.. Just wanted you to know I have done what you are speaking of, but it's not practicle, not by a long shot.
Jay
Well... it doesn't double it, no. But it does massively increase the bitrate by about 50%. Which doesn't violate the standards because while the recorded bitrate is hugely increased well outside the standard, because the playback rate is set for slower it gets averaged out across the playback rate, so the net recorded bitrate appears lower, which fits within the standard. Clever solution.I'm assuming the AF100 does not double it's bit rate when shooting in 60p to 24p over crank mode. Seems this would violate the standards for the in camera codec.
HD-SDI is incapable of showing 1080/60p. It is not possible. The maximum that HD-SDI can support is 720/60p or 1080/60i; 1080/60p would require it to support twice the bandwidth. So when you go into overcrank mode, the AF100 embeds its 60p signal into an SDI-compatible 60i signal. You'll still see live monitoring.I wonder what it's doing when spitting out info via HD-SDI?
I just did abunch of testing with the 1080p 60p over crank. Its astounding. You guys wont be disappointed.
The SDI output in overcrank mode? It'll be fine up to 30fps. After that it's half-resolution for some frames. Not really something you'd want to record.I wonder how "usable" the SDI output will be. Would be kinda neat to be able to shoot overcranked to the SD card but record the same shot in realtime using a recorder. Then again the shutter speeds would be a bit off no?
