If you have no lighting equipment available, you're likely not going to get very good results. Shooting at night doesn't mean not using lights -- night scenes require as much light, if not more, on your subject as day scenes do.
1/3" HD cameras are at a disadvantage when it comes to "low light" shooting to boot. You need to have plenty. An image is made up of light; without it, you have no image.![]()
Well, your first concern is getting a good level of exposure on your subject. Your second concern is keeping the light away from where you don't want it to go -- to create mood, but also to create sufficient darkness in the scene to give the impression of night. Your third concern would be to use an appropriate color of light so as to simulate your "natural" light source -- the moon, or a street lamp, or whatever. (This is a much lesser concern than the other two, especially considering the color adjustments which can be done in-camera and in post).
So, light is light, and there are many different types of lighting out there; you'll be able to get a good exposure cheaply, but the more professional the gear, the greater level of control you'll have over the light.
That's pretty standard, so it's fine. You'd change the shutter speed if you want the motion characteristic be different (choppier, or less choppy).
Keep in mind, though, at 1/24 (360 deg), you lose much of the cinematic motion cadence; the movement will start to look video-ish.
