Advantage of an Hpx-500 vs Dslr Camera?
vision_filmz
Carbonite Member
As a current Dslr user and now I will be working with a friend who works for a company that uses these cameras I would like to know some heads up.
I keep hearing people say that the codec cuts like butter and works very nice in the editing stages. Also what main advantage does this camera have over dslrs.
Sorry for the noob question, just want to know what exactly makes this camera better.
Well, where to begin? A nice camera is more than just about image quality, there are many factors such as ergonomics and robustness that can be very indispensable depending on your needs. Here's a small list off the top of my head:
Form factor: If you learn how to use an ENG cam, you'll be able to pretty much use any professional camera regardless of make or model, as most share a very similar layout and support the same features. They are much more comfortable to use out of the box than dSLR's which need rigs and viewfinders to make em work, the camcorder will have all the connections you could possibly need for audio, monitoring, remote control, external recording, ect.
Build quality: Modern ENG cams, especially those using solid-state media, can be used in just about any hazard nature (and sometimes mankind) can throw at you and keep working; there's no junk like shutting off from over-heating, limited record times, outrageous skew, ect.
Codec: dSLRs record data at 44~50mbps 4:2:0 long-gop at best, which doesn't exactly have most people jumping for joy. More robust codecs such as DVCPRO HD record more color data at higher bitrates and encode every frame instead of spreading data out over several frames, which is much more convenient in difficult situations such as when flash photography is being used, or you're shooting footage of something like ocean waves and other unpredictable, high-detail subjects. What people mean by "edits like butter" is the fact that you can pretty much edit DVCPRO footage on just about any computer made in the last 10+ years, and it's widely supported.
I could go on, but the point is, the only things I find nice about dSLR cams is the selective focus, compactness and low cost. If you need any combination of those things, which people often find they do, then you know why they've become so popular, otherwise a camcorder is almost always better, especially in situations where a narrow DOF is not needed.
Thanks for the reply. Now on the flip side to that can you answer some things where a Dslr is better than an Hpx500
* Performs better in less light
* Can achieve selective dof
* Price
* Interchangeable Lenses
That's only a few I can think of. I think the P2 media that is used to record is a lot more professional than Sd cards. Also the higher bit rate and color sample of the hpx500 is something that is really important as well.
Not to cause an argument here with anyone, just wanting to know more about actual users who have used both technologies
thanks
The HPX is going to be just as good in low light as the dslr. The larger chips helps a lot with that. The HPX also has interchangeable lenses....ones actually made for shooting HD video (but yes they are more expensive) and you can def get SHALLOW depth of field with them. And sure the price is a little up there....but it's not really an issue if your a serious videographer investing in your business. I like DSLR's but only because they produce some pretty decent film like images. But I personally would never choose one over an HPX500 or similar camera. If the HPX wasn't filmlike enough to soot my needs I'd rent a RED. After all how many "serious" film productions buy their cameras? rarely any.
2/3" 3-chip cameras do perform rather well against dSLRs because of the 3-chip design, there are some pretty high-end cameras that do utilize a single-chip designs, but unlike SLR cameras they actually down-sample the image instead of line-skipping.
If anything, SLR cameras perform better in good light, because even with -6db gain on some camcorders, you are still probably at ISO400, whereas dSLR cameras can go down to ISO100 and even ISO50 for squeaky-clean images.
While having a variety of lenses makes sense in photography, where image quality must remain critical regardless of the intent of the lens, in video things are much simpler. By and large, you just pick a wide zoom or long zoom, 2x extender or not, and call it a day. You really won't need anything else because a good video lens is most likely going to be sharp at any focal length, have macro, a rather wide aperture, and an extreme focal range; you would need over a dozen 35mm lenses just to do all that.
Also although you can knock a background out of focus using a 2/3" camcorder, it's most likely going to be done at a long focal setting, while dSLRs do have the advantage of being able to do so even with wide lenses.
That said, you can't truly say which is "better" because they serve different stylistic and practical purposes.
Thank you for your professional post, truly great to hear from someone with knowledge on this matter.
Hpx500 is a professional Camera with pro controls for video and audio which a dslr does not have, you have to use external mics and audio recorders to get good audio with dslrs, so that's always a problem when you need to record audio.
That's very interesting regarding the way the Hpx500 uses it's chips and I honestly did not know that a dslr with a lot of light can produce a super clean image as opposed to other cameras which are at higher iso's
Very informative, :)
I have found the color space to be off in the DSLR world (5D, 7D) if you are editing and producing in the YUV colorspace for television. If you put a Mac Beth chart in front of a 5D and an HPX-500 you will find the DSLR to be pretty far off when viewed on a proper production monitor.
I tried to match the 5D to the HPX-500 (using a chart) and pretty much gave up because to get the colors correct on the 5D I have to push to the level of posterization and it still was not true. So if you are shooting for broadcast the true "video" cameras have an edge because that is what they are built for.
vision_filmz are you alluding to the fact that you think my response was not "knowledgeable on the matter"?
Kolor-Pikker is most certainly correct with his statements. He exaggerated on on some of the things that I had mentioned.
His post was less biased than yours. When you say that Dslr's produce a descent film like image & hpx500 is not expensive if you are "Serious" . Just rubs me the wrong way.
Many amazing projects have been shot on a Hpx-500, but many have been shot on a dslr as well. So much so that No One can deny the "Picture Quality" alone of either project. So please lets not get into actual quality as I have seen amazing projects shot with both cameras.
First of all my post wasn't "biased." It's just my opinion. I wasn't hacking on anything. I even stated that dslr's produce a nice film like image. I did not mean to rub you the wrong way. It's just one guy's opinion. I don't have any issues with dslr's nor with the issue of people choosing them over other cameras. And I def. didn't say anything about or deny "quality" of either camera.
I apologize for offering my opinion. I thought you wanted people to chime in. It seems that you have your mind made up about the DSLR considering you are defending it sooo much when there is no need to be defensive. I merely wanted to say....I personally prefer the HPX500. DSLR's are nice but not my cup of tea (PERSONALLY/OPINION). If I want the film like quality I'll rent a red.
How old are you? You act like a child + why did you care that I did not comment on your post. Screaming for attention much?
It's impossible to do a thread like this because of people like you, I dont care about a red nor any other camera that was not mentioned. All I asked was the benefits yet you chimed in on some other stuff.
You had your opinion well this is mine, Time To Grow Up
Wow, Mr. Vision. I think you need to step back a bit. Your first post states you are a noob and you want to know why the HPX-500 is considered better. That is quite a loaded starting point to your thread.
Listen, cameras are cameras. I have used a lot of them and using them remains constant. You use the HPX-500 or ENG camera in the same way you use or can use a DSLR for video. Focus, exposure, framing, audio all to be used.
I am wondering what you are trying to figure out starting a "thread like this"? A less defensive tone might yield more information. Just sayin'...
Poor mb72378 - and agreed with Bassman! This is outrageous and childish behaviour and by god you really do owe mb an apolagy... This is just the kind of behaviour we so often see when a new product type inspires a range of pretentious 'noobs'? who feel the egotistical need to trump up there ten minute zeitgeist for all to see.
God what a joke, i think the mods should consider locking this or deleting it - its a one of a million noob pick a fight threads...
Relax boys. It is chocolate and vanilla. Just use what you like and don't slam a guy for liking the other flavor. I have both an Hpx-500 and a 7D. I myself like chocolate and vanilla and am very partial to the RED flavor...(but that is off topic).
Make movies....Have fun!
HAHAHA, red flavor tastes nice. I really do think that the Canon 5d Mark ii produces some very pretty pictures. I haven't looked into the 7d though. Ill have to check it out.
So now you feel the need for name calling? The ONLY person who brought negativity here was mb72378 , I just told him I did not care for it.
Noob in the sense of an Hpx500, but far from noob when it comes to this Vision. At the end of the day it is impossible to have this discussion with people who are so sensitive about their cameras. I commend Kolor-Pikker On keeping it professional and would suggest everyone to learn something from him
Good Day
/End of thread
You guys are unbelievable.
I'll read this thread again in the morning and decide if someone will get a time out. Maybe. I'm too tired for this stuff now.
- Mikko
Two words: Picture styles. Using the picture style editor, it's possible to photograph the chart, adjust colors in the editor as you see fit, save changes as a style and upload it to the camera via EOS utility.
Picture styles are applied to the recorded image before it is encoded, so technically the best way to go about using dSLR cameras is to "pre-grade" your footage so you get close to the intended look in-camera, and then make only small adjustments afterwards. You can read more about it here: http://www.canon.co.jp/imaging/picturestyle/editor/index.html
It's also my opinion that I'd choose to use my 370 over the 5D for most purposes, and it only has a 1/3" sensor. dSLRs are great special effects cameras, I'll give em that, but I'd probably intercut footage from other cameras too.
Edit: wtf? where did all the trolling come from while I was typing up this post?
Thanks for the link about the picture styles, but I am trying to figure out this fit for a video workflow. I shoot RAW with my still work and I have custom profiles for still processing in Adobe Lightroom, so I am familiar with the process. But the link you sent seems like it only applies to RAW processing in the Canon software in an RGB color space (computer monitor). How would you go about setting the camera up for YUV? Maybe importing the adjusted image into an NLE then re-adjusting over and over?
