From http://www.seriousmagic.com/help/dvcProHdSoftwareUpdate.cfm
DVCPro HD Decoder / Batch Converter Software Updates
2/7/07 - DVCPro HD Batch Converter Version 2.1.1581.0 Free Update (6.85 MB)
NOTE: The first time you launch the Batch Converter after installing this update, you will be prompted to activate. Please choose the "Upgrade Now" option. If your computer does not have an internet connection, call 1-866-205-6310 to get the necessary code.
- Enhancement
- Help system added.- Enhancement
- Added QuickTime for Avid as an Output Format option.- Enhancement
- Added Minimize button to title bar.- Enhancement
- Added "Remove All" button for clearing the Input Files List.- Change
- Output Filename field moved to its own region, "File Setting," in the interest of clarity.- Change
- "First Sample" and "Last Sample" fields removed because they were neither intuitive nor particularly useful.- Fixed
- Converter did not work correctly with DVCPro HD 720P/24PN or 720P/30PN clips.
- Note: Variable Frame Rate Clips in the Native modes will not have audio.
- Fixed
- Intermittent crash while converting a batch of clips.- Fixed
- Converter would silently overwrite existing files. It now asks whether you want to skip or overwrite.- Fixed
- Behavior was undefined if no Output Directory was set. Program now prompts to set this path.- Fixed
- Output Directory path could not be set if Input Files table was empty.- Fixed
- If the proper file extension for the output format was removed or revised in the Output Filename field, the resulting clip would not have an appropriate extension. The program now adds the correct extension in all cases.- Fixed
- Unsupported file types could be dropped into the Input Files table.
