Can someone who is more familiar with Premiere Pro CS4 fill me in on what I'm missing? I downloaded the trial and I fear due to the program's complexity I am probably missing some points. Right now I'm close to uninstalling Premiere Pro CS4 because:
(1) It is incredibly slow at rendering. It takes Premiere Pro CS4 5 minutes on my quad core 2.8 Ghz machine to render a 1080 video that is less than a minute in length. PowerDirector renders the same video in 27 seconds... and at higher quality. I'm running the 64 bit version of Premiere on Vista 64 which they claim will be 227% faster than the 32 bit version. I'd hate to see the 32 bit version!
(2) Premiere Pro CS4 can't even open the native MTS files from the GH1. You have to convert with something like NeoScene first.
(3) Premiere Pro CS4's export options are very limited. I have many more options in PowerDirector. Where's the option to export a 1080 MPEG-2 file in Premiere?
The only reason I'm trying Premiere is that, as far as I can tell, PowerDirector will only let you edit/create projects in either 30 or 25 fps format. It can't do 24 fps.
Anyone else compared these two programs or at least found an affordable solution to edit 24p native video?
Mike
Mike
