That is how it is done.assign an ISO to the three gain presets.
That's been discussed much, and lots of us agree that more control is better than less, and I've asked them to add that to future designs.Wish there was a way to tweak the ISO on the fly w/out having to go back into the menu.
I don't understand why not? It's been enough for every video camera since the dawn of time... in fact, after doing tons of field work in video cameras, I can say that ONE ISO is usually enough. Adjust exposure using the ND filters and the iris... man, back when I was shooting events we *never* touched the gain. Ever.3 options are nice but not enough for run & gun field work.
.The next best suggestion is too just not use the camera at all in ENG
In my view, the archaic concept of a fixed, pre-set ISO should've been tossed out a decade ago, along with the film cartridges (and DV tape for that matter). Aside from challenging lighting conditions where it's necessary to set a fully manual exposure, I don't want to have to touch the video gain control either. What I want is to set the aperture and shutter speed using my own judgment, and train the light meter on the area I want the camera to expose. It should then select the hottest exposure that won't blow out the highlights, and hold those initial settings for the duration of the video take. The entire concept of a fixed ISO set in coarse 1/3 stops is an obsolete concept from the film era that obstructs my workflow rather than simplifying it....It's been enough for every video camera since the dawn of time... in fact, after doing tons of field work in video cameras, I can say that ONE ISO is usually enough. Adjust exposure using the ND filters and the iris... man, back when I was shooting events we *never* touched the gain. Ever.
Ideally, I'd set shutter speed to control motion blur and aperture to control depth of field. What would make an automatic ISO usable in practice would be a good histogram display or waveform monitor. With the light meter trained on my subject, a half-press on the shutter would set ISO and the histogram would show me the exposure profile. If it was too hot, I'd lower it with an ND filter. If it was underexposed, I'd readjust aperture and/or shutter speed to get a better exposure. I'd also want to be able to set a gain limit in advance, to keep worst-case ISO noise under control.Basically you want an automatic ISO yet you still want to set the stop and the shutter speed.
How would you set these if you did not know what the ISO (asa) was?
Right, it's less convenient, but ... I don't know, to say it isn't "enough"? Like you couldn't actually do the job?
(and yes, I agree that using the AF100 for ENG-style work is far from ideal anyway). If I had to do it, I'd probably use the 14-140 at ISO 800 or 1600, and just use the iris wheel. Of course, the bigger problem there is that the iris wheel response is so slow on the Lumix lenses...
Yes, when you factor white balance and individual RGB gamma curves into the mix, exposure becomes a non-linear function and ISO may no longer be simply scalable. But in practice, I almost always attempt to make best use of the camera's limited dynamic range by setting exposure levels just short of blowing out the highlights. With well-engineered firmware, I have no doubt the camera could do this more reliably than I can. I use color correction in post to handle scene-to-scene exposure variations in my own work, and I expect that correctly exposed auto-ISO footage would be no different.You would have to be very confident that varying the ISO gives you consistent / constant scene to scene results. (gamma, noise, knee etc)
Why would anyone design a function into a camera designed for a different purpose?
If there were a better, faster ENG lens for this camera, the iso flexibility would be less needed. There's nothing else that covers the ENG focal lengths of the 14-140 in one lens and also has the quiet servo capability via remote rig mounted remote.
