While the Panasonic website kits the GH5S sensor as 17.3x13mm, the overall sensor size is closer to 19.3mm wide, but only uses 18.9mm of that width in 17:9: and 17.75mm I. 16:9 Video aspect ratios. The GH5 is also listed at 17.3x13 — but in the release interviews, Panasonic states the new GH5S has a larger, multi aslect sensor similar to the GH2 had (which was 19x13.4mm to get a 22mm image circle at the various aspect ratios could line up in). This “larger” sensor according to Panny precludes the use of IBIS, so what is the actual image circle and sensor size.?
After first after hearing the rep, I figured is was close to the AF100 sensor size 17.8x10mm (which was optimized for 16:9), to get the continuous aspect ratios, The advantage of the GH5S is that all the various aspect ratios (except 1:1) use the same number of pixels and have a constant diagonal size.
The GH4/5 however, crops the sensor for 16:9 or 3:2: and use a smaller area of the smaller 17.3x13mm sensor. Since the GH5S is supposedly the same as the GH2, which was 22mm, the GH5 at 4:3 is only about 21.5mm, and even less in 16:9 The GH2 maintained 22mm in 4:3, 3:2 and 16:9 (also in 1:1), the GH3 did not, and went from 19.8mm in 16:9 to a 22mm image circle in 4:3.
The GH5S is supposed to hold the image diagonal and pixel count for each aspect ratio, except 1:1, which is less, so it needs to be bigger than the 17.3x13 advertised size. This was also demonstrated recently, with APS/C zoom lenses having a 30-34mm image circle vignetting on the GH5S with the 0.71 Speed Booster, so the sensor needs to have at least a 22mm diagonal to cause this issue, the smaller sensor with a 19-20mm image circle should work at a 0.64 focal reduction factor with a APS/C lens image circle of 30.5mm. The math just does not add up to support a 17.3x13mm sensor.
So, the question remains, whu is Panasonic not listing the actual sensor size for the GH5S?
Cheers
Cheers
