ActionProducts Voodoo line for Blackmagic Cinema Camera
Justin R Goff
DVXuser Sponsor
ActionProducts Voodoo Master
Master Black Magic with the "ActionProducts Voodoo Master", sold exclusively from Innocinema. This first edition to the "ActionProducts Voodoo" line will allow you to master your Blackmagic Cinema Camera with unparalleled functionality in this sexy, sinister compact piece.
--- PRE-ORDER NOW – 20% Deposit Code: "VOODOO" ---
  • When pre-ordering, minimum 20% down payment accepted.
  • Use our 20% Deposit Code "VOODOO" in the "Discount/Deposit Code" box at checkout.
  • Remaining balance will be required before delivery
Internal In/Out Power System: Fitting on the bottom of the camera, the Voodoo Master has an exchangeable 14-Volt battery system, which will power the Blackmagic Cinema Camera with 12-Volt, and 5-Volt Accessories. There also is a power-in, allowing power from an external source, such as V-Mount and Anton/Bauer Battery systems or AC-Power.
XLR Phantom Power Audio: 2-Channel XLR Phantom Power ready connections are on the right side of the Voodoo Master. These connections were placed on the right side on purpose to allow the cords to be neatly out of the way when using a shoulder mount configuration. There are individual on/off switches for each channel, allowing you to choose which channel to power or not.
15mm Lightweight RodMount: There is a 15mm Lightweight (60mm spacing) RobMount built-in the body that passes from the front to the back, allowing you to mount accessories on both the front and back of the Blackmagic Cinema Camera, such as a Matt Box or Follow Focus Motor in the front, and any accessories that can mount to 15mm Rods (60mm Spacing) in the back. This includes the ActionProducts V-Mount and Anton/Bauer Battery Modules coming out soon for the Voodoo product line.
BridgePlate Ready: The Voodoo Master is also sized to be able to mount to any industry standard BridgePlate on the market, allowing for configurations with 15mm Studio (100mm spacing) Rods or 19mm (104mm spacing) Rods. Having the ARRI Rosette on both left and right sides of the Voodoo Master body, allows for professional handle placement for any configuration.
  • Exchangeable 14-Volt Battery for Camera + Accessory Power
  • External Power-In (V-Mount, Anton/Bauer, AC-Power, etc.)
  • 2x 12 Volt Accessories
  • 1x 5 Volt Accessory
  • 2x XLR Audio Connections
  • 2x Audio Phantom Power On/Off
  • Left/Right ARRI Rosettes
  • Built In 15mm Lightweight RodMount
  • Bottom Threads for BridgePlates
New Site and New Products!
We're thrilled to announce the launch of our new web site at innocinema.com! Our aim was to completely redesign a new touch and feel that will dramatically improve your on-line experience. Since we redesigned this site primarily to benefit you, we want to know what you think about it!
We would also like to take this chance to introduce new products as well. We are adding the ActionProducts EVF Arm Mount for the EPIC/SCARLET accessory line. The EVF mount is made to integrate seamlessly with the ActionProducts left side cheese plate and features flexible mounting positions.
Another mention goes out to ActionProducts new line of "Voodoo" accessories. These products are made specifically for the Black Magic Cinema Camera. Be sure to check out the "Voodoo Master" and check back later for additional accessories to the "Voodoo" line up.
[TD="class: td1"] As we respond to feedback from you and others, we will work to add additional information and integrate helpful features into the web site. Just send your messages to contact@innocinema.com. Please be patient with us as we work towards making any improvements. Again, if you have any questions, comments, suggestions please don't hesitate to contact us at any time. We look forward to hearing from you! [/TD]
201 S. Tryon St. Ste 875, Charlotte, NC 28202 USA - Pnone: (704) 6651945 - Fax: (704) 6651956
