Why in the world would Pana put a non-removable lens hood on this thing?
Ken
Also you can't put on a wide angle adapter.
It works like all the Panasonic focus rings since the dvx100: no stops, but precise movement as repeatable as if it was a mechanical linkage.Is there some chance there are positive stops on the focus ring, or real linkage to the lens.....just dreaming
Grant
It provides for either component or composite output. The cable has r/g/b component, yellow composite, and red/white audio connectors.Just noticed in the photos there is a port named av-multi; what is that? If it is component, it is a different plug than used previously.
Grant
Yes. Full size.Looks like the HDMI connector is full size?
Pristine perfect 4:2:2 output.Barry did you mention clean 4:2:2 out of the HDMI?
All the same controls as all the other AVCCAM units. All the same menus as the AF100, AC160, AC130, HMC150, etc.I wonder how much image control it has, as in cine gamma/Matrix type tweaks?
