AC90: AC90 and Pre-Record
Bo Sundvall
Hi
I have a question about Pre-Rec on the AC90:
On my TM900, if I chose Pre-Rec, after each time I press record and want to use Pre-Rec again, I must enable it in the menu. It's disabled automaically each time record is pressed. I know I've asked abot the Pre-Rec function on the AC130/160 and on those models, as I understand, it is enabled as long as the camera isn't powered off.
I find Pre-Rec very handy in many situations, but the way my TM900 works, it's not so practical as it takes time to enable it every time it will be used.
Does anyone know if the Pre-Rec on the AC90 works as on the AC160, that is, enabled even after record of one scene?
Regards,
/Bo
Pre-record has limited use on the AC90. You need to dig through the menu for each and every use. You can't even set up a user button to enable it as far as I can tell.
