macgregor
Given that with my tests I get the following results, showing that cine4 has the same ammount of DR than S-Log2...
... I said today, what if I underexpose the cine4 by 1 2/3 stops (which is quite a lot actually) so that I get the dynamic range allocated in the same way the Slog2 profile does (more highligths, less shadows)? Maybe I will be able to get less noise since I can use a much lower base ISO setting (200ISO in cine4) and also, I won't need to use ultra heavy ND filters anytime I want to shoot with this camera.
I did tweak the black levels and gamma on cine4 all the way up and the footage so that it fills about the same histogram bucket that the Slog2 profile does.
Some grading in Davinci and here you go:
Don't ask me which is which because it's hard to tell. They have the same DR so the differences are very subtle. Saturation in the highlights changes a bit here and there but wow, not a bad match!
So which one is which then?
Lets zoom in 400x:
Noisy pics --> Slog 3200ISO.
So what's the catch then? Donno. None so far. But I've only been playing with this for a couple hours.
Will the footage be more prone to posterization? Mayyybe. BUt at the same time, it fills the histogram the same way Slog does. So it could just be the noise in the Slog helps avoiding posterization in the compression. I need to test this with an external recorder to see if it´s the codec or the internal processing.
But the best thing is that the camera could now be rated to a much more decent 640ISO and while keeping the same amount of DR in the highlights, it shows less noise. Win win situation?
Lets zoom in 400x:
