So I just noticed the internal mic on my A1 isn't recording or picking up any sound. Is there a option or button that may be set that is causing this? Or is it flat out broken. If broke, will an external mic plugged in likely work?
The XLR option is turned off in the menu. So I assume the internal mic is broke? Is there an easy way to take apart the handle to inspect the wires leading to the mic?
If the internal mic is broke, should a plug in XLR work? Whats a decent affordable XLR?
