So am I going to need to get an spic if I want to use my own glass, or is the scarlet going to have a non fixed version? That question probably has no answer because of the lack of info. But I would like to see a cheaper scarlet with jut a nikon or canon mount.
Jon
Poppycock.
Physical FF will never be "useless".
I have several.
That isn't the point.
The point is that defining two touch screen points on a 5" monitor to pull focus on isn't going to be as precise or as predictive as a trained AC with experience and skill.
Period.
just like to clarify about the 3k bayer not full being resolved, the same is true of every single chip bayer camera none resolve their full resolution, check them on focus charts, so the argument well it's not 3k would be the same as saying the 5d is not even 1080, or the 7d, or the GH-1, or the ex-3, or even the f35 (not sure about that one but I believe the only high end camera to resolve a full 1080 is the genisis). so to say it will make great hd but not 3k is a misstatement to me at least until we see it, it is said it will resolve around 2.4k considering some "HD" cams only resolve 600-700 lines yet we use them for HD I can assume scarlet will do a fine 3k when needed and even a fairly nice blow up to 35mm film, but who knows I could be horribly wrong on some of this.
This is true.just like to clarify about the 3k bayer not full being resolved, the same is true of every single chip bayer camera none resolve their full resolution
Well, that's not a fair statement, because none of those are using the full chip as far as we know. They're all line-skipping or pixel-binning or some other technique, and no, none of them resolve a full 1080p. But if you want to talk about the native chip resolution, it would be fair to say the 5D isn't 21 megapixels, because its 21mpix sensor is Bayer, and therefore will resolve a true 14-16mpix. And you could say the 7D isn't a full 18mpix and the GH1 isn't a full 14mpix, because both have to go through the demosaic process and will shed 20%-33% of their nominal resolution during that pricess.so the argument well it's not 3k would be the same as saying the 5d is not even 1080, or the 7d, or the GH-1
EX3 doesn't use any manner of Bayer patter, it's a 3-chip camera and that technology is capable of resolving a full 1080p.or the ex-3
The F35 is the Genesis, basically. You can't buy the Genesis, but you can buy the F35. And they use an RGB Stripe sensor with significant oversampling so yes, they do resolve a full 1080p.or even the f35 (not sure about that one but I believe the only high end camera to resolve a full 1080 is the genisis).
No, it's perfectly accurate, and even the folks at Red would agree. The "3k" mode will deliver, at best, about 2.4k worth of resolution. Which is the same reason why the Epic is offering a 5K mode, because the "4K" of the Red One isn't a true 4K either; you have to start with at least 5K to end up with a real-world 4K once the de-mosaic process is finished. If you shoot 5K on a Red, you'll have about a 4K image when you're done. Shoot 4K, you'll end up with 3.2k. Shoot 3k, you'll end up with something better than 1080p. Shoot 2k, you'll end up with about 720p.so to say it will make great hd but not 3k is a misstatement to me
Don't confuse lines of resolution per picture height, with "3k" or "4k" notation, they're not the same. If you want to compare video against k, you can use 2K vs. 1080p, as they're basically the same.considering some "HD" cams only resolve 600-700 lines
It will likely do a lovely blowup to 35mm film. The DVX has been blown up to film many times and looks pretty darn good, and that's a 0.3k system. So the Scarlet should do just fine. Then again, we've been seeing great filmouts from the HVX for five years now, so worrying about whether something will hold up on a film transfer is something that's been a long-settled issue for many years.and even a fairly nice blow up to 35mm film, but who knows I could be horribly wrong on some of this.
well i still don't think that is the case as they play 4k red one material in 4k, so hence if there were a 3k it would be able to play at that.
Well, that's the thing -- Red doesn't do much to dispell the confusion either. Statements such as "data to burn" and "pixel shift not spoken here" and "4:4:4" are just plain misleading. There is not, in fact, data to burn. And it doesn't record 4:4:4 color sampling, or anything within a mile of it. And while it may not do "pixel shift", it does do a bayer demosaic, which Graeme said is a very similar process.like will 3k from scarlet look good at 3k I don't think we can say for sure till we see it, though I'm not getting my hopes up.
It is indeed. Which is why I say don't listen to what the marketers tell you; instead evaluate the product for what it *actually does*.knowing is half the battle
