A work-around please
Poco
I screwed up. I taped a wedding with one camera in 24p and one in 24pa. :(
How do I fix this, how do I capture?
I'm not fussy as to a 29.97 or 23.98 timeline, I just need to edit it.
I feel like an idiot.
The way I would do it would be to capture the 24p in a 29.97 timeline & the 24pa in a 23.97 timeline, render out the 23.97 to an AVI file when it was completed then import the AVI file to the 29.97 timeline where you have the 24p footage & continue the job so all will match.
If you're using Vegas, EDIUS, or Premiere Pro CS3, you hve no issues. Just capture the footage and edit on a 24P timeline. All those editors know how to remove the pulldown on the fly.
Thanks guys
I did the reverse telecine on the 29.97 clips and the item properties now show the clips at 24fps not 23.98.
Does that matter?
capture both as regular 29.97 DV. you only get 24PA if you check advanced pulldown removal. otherwise 24p and 24pA are the same - they're both recorded to tape at 29.97
Thanks ... I've never used 24p before only 24pa. On the 29.97 timeline do I still have to reverse telecine or leave it as is?
You would leave it as is.
However, 24pA footage left as 29.97 might show a bit more of a strobe. Doing this is the EASIER way to go, but it's not necessarily the BETTER way to go.
What would be the best way to go? It's a wedding video I need it to be as good as possible.
Thanks ... that's what Adam74 said further up the thread.
So, now my only question is ... my 24p footage shows as 29.97 in the item properties.
That's fine but when I reverse telecine it now shows 24 not 23.98 in the item properties and when I drop it into a 23.98 timeline fcp wants to change the timeline to 24p. Is that OK? Can I mix 24 and 23.98 in a 23.98 timeline?
WHEEE!! All is good! Thanks all for the help and especially the link David!
I'm back in business - this site rocks! :2vrolijk_08:
