puredrifting
Major Contributor
I was chatting with DVXer SlavikB and he mentioned this mic to me. It's called the Polsen VM-101. You can get it at B&H Photo here for a mere $39.95 https://www.bhphotovideo.com/c/sear...InitialSearch=yes&sts=ps&typedValue=Polsen+VM
Why would you want to put a cheap microphone on your C100 MKI? It's simple, weight and size. Canon neglected to build in any in-camera mic like they did on the C100 MKII and the C300 MKII. So if you want to, for instance, mount your C100 MKI on a gimbal like the Letus Helix Jr. or the Ronin-M, or on a slider or crane, where you often cannot use the handle/mic unit because of size and weigh issues, how do you record audio for a scratch track to help you/the editor sync in post? This has been the quandry for quite a while. Of course there are decent, brand name choices like the Røde Video Mic Pro and Pro+, the Sennheiser MKE400 but you are then spending hundreds of dollars, merely to get a scratch track onto your C100 MKI. Seems like a waste. Many have been looking for a cheap , small and light self-powered mic for recording an on camera scratch track but it has been challenging.
Before we go on, hopefully none of you are using these sorts of mics on your C100 unless it is merely for ambient tracks or unless you are sticking the camera right in the face of your talent at about 24" away. Most shots of faces from 24" are not going to be flattering. On camera mics are generally useless for anything but ambient. I've rarely understood those who put a $2,000.00 mic onto their camera mount, what a perfectly good waste of $2,000.00. I just ordered the Polsen VM-101 from B&H Photo and thought I would give it a try. I recently acquired a Letus Helix Jr. gimbal and need a way to record scratch tracks while shooting with it so my clients will be able to easily sync with the quality audio that a sound mixer will be recording. The VM-101 arrived today, I opened the box, knowing that for $39.95, it probably wouldn't be good, undoubtedly wouldn't be professional level, buit I thought it was worth a try.
The Positives
The price - $39.95 for a solution to a problem that has plagued us is better than dropping $200,00 to $350.00 for a name brand self-powered mic, if all you are using it for is to give the editor a scratch track . Remember, mounting a mic on a camera is generally deluding yourself into thinking you might record something with it that sounds passable. That rarely happens, due to those pesky laws of physics.
The Polsen VM-101 comes with a built-in shock mount of sorts, a foam windscreen and a dead cat to cover the foam
It's powered by a single AAA battery
It affixes to your cold shoe where the handle/mic normally attaches
It has a small led battery indicator light above the power switch so you can verfy your battery is powering the mic and hasn't died
The supplied dead cat looks amazingly like one of those troll dolls from the 80s or like an aging Trumpian hair style where is his orange has faded to white
The dead cat actually works somewhat and reduces wind noise and buffeting sounds
It weighs a mere 1.8oz! Perfect for gimbal use where every extra ounce counts.
The Negatives
The build quality is fragile looking and feeling. It seems that if you drop this onto a hardwood floor or concrete, it will shatter
The built-in suspension seems to be a bit too soft as the weight of the mic cable when plugged in makes the mic list to one side in some of the pictures below.
The sound is pretty bad. A lot of hiss, and a mid-range emphasized honky sound
Summary
We'll see if this mic will last long enough to actually be used on a few paying projects. As stated, it sounds pretty bad, which I expected it to. But will it work long enough to record some usable scratch tracks? Stay tuned.
The Positives
The Negatives
Summary
